Results 1 to 4 of 4
Thread: Ideal Machine For My Projects?
    Jun 2006
    Hello
    For the last 3 years I've been producing make custom branding irons using a Plasmacam table & CNC but I'm extremely limited with the items that I can cut. I get complex logos with free floating pieces and I have to pass on the job.
    I've been asking around and I'm told that milling is going to be my best bet. I'm looking for a milling machine that could produce a piece similar to that found on the homepage at Brandish dot com.
    I'm not looking for a large production machine because at best I see maybe producing 4 or 5 a month but larger orders could come so something that may be expandable would definitely be nice.
    I have a small shop so I need something bench top or slightly larger.
    I'd appreciate any feedback.
    Best regards,
    David L.
    Mar 2006
    I'm just a hobbyist and these are only opinions.
    My cnc mill could cut those pieces no problem. They'll look "milled" though and I don't know what kind of finish you require. Do you also hand finish them?
    I have done a few raised lettering type pieces with excellent results, but again they have that nice "milled" look to them..But I like that.
    Looking at your sample it looks like there may be some pretty small cutters required. That requires either a lot of spindle speed or very slow table feed which can really slow down the job. Something to keep in mind.
    I have used 1/16" solid carbide endmills in my x3 mill in brass for that type of stuff. They break easy though. I would think you'll need some V cutters.
    If only making 4 or 5 of those a month I am sure a cnc mill would work out. And of course a cnc mill sure might come in handy for tons of other stuff.
    Steve
    Jun 2006
    Steve
    Thanks for taking the time to reply to my question. The 'milled' look doesn't make that big of a difference as long as it leaves the correct image when it's heated and used for branding.
    Do you have a few smaller mills that I may consider?
    Thanks again,
    Dave
    Jun 2005
    What materials will you be cutting? The X2 w/ some of the CNC retrofit kits might be a good option. Smaller would be a Taig
