Results 1 to 8 of 8
Thread: Advice on Small CNC Mill - From Scratch or Pre-Built?
    Nov 2006
    Greece
    Question Advice on Small CNC Mill - From Scratch or Pre-Built?
    Hi all,
    This is my first post and I'm a newbie when it comes to CNC milling . I'm an electronic engineer and would like to build/buy a small CNC mill to be used for
    - Panel designing (arbitrary holes/openings on sheet metal & label engravings).
    - Milling of small parts for use in my own projects.
    - Cutting tool travel: x = 150-300mm, y = 80-100mm, z = 50-80 mm. Longer/shorter travels may also be OK.
    The material would be almost exclusively aluminium sheets/blocks, and a bit of copper & plastics. I'm very experienced in electronics, so I can easily handle the stepper motor control and s/w interfacing part. What I cannot do/choose easily is the mechanical part. Should I buy a ready-made mill and convert to CNC myself (by attaching 3 steppers to the x, y, z knobs), or should I buy separate parts like CNC rails/bearings/slides & drill and combine them together to build my own CNC mill from scratch? Another option is to buy an already-converted mill like the ones from Proxxon, Sherline and Taig.
    My priorities are (highest first)
    1. Machine precision, robustness & repeatability.
    2. Compatibility of controller with easily available & good quality s/w (Mach3 or others).
    3. Relatively low cost (say, up to $2,000 - I'm only a hobbyist, not making money out of this).
    The easiest solution would be to get a ready-made CNC mill retrofit, like one from the following.
    - Proxxon MF70 (http://www.usovo.de/).
    - Sherline (http://www.sherline.com/).
    - Taig (http://www.taigtools.com/).
    A friend of mine has just bought the Proxxon MF70 (which comes with the SMC-800 controller), but he's now discovering that there's a serious lack of good and cheap s/w for this controller. He's already spent a lot of money on s/w (WinPC-NC & Filou-NC) and still hasn't been able to really use the machine!
    What do you guys think/recommend I should do? Which ready-made mill would you suggest I get? Or maybe build it from scratch? I found this link in the UK that sells parts for linear movement.
    http://www.marchantdice.com/
    Any pointers or information is greatly appreciated.
    Apologies for the long post & thanks to all for the great forum & info.
    Costas
    Aug 2006
    UK
    Hi, a couple of months ago, I bought myself a Sieg X1 and CNC'ed it. It was quite a lot of effort researching and sourcing the motors, the motor mounts, the drivers, the PSU and the CAM and machine controller software, and it ended up costing me a lot more than I expected - making some of those prebuilt CNC machines look like good value.
    I am already considering a larger machine as I want to be able to make bigger parts and to make small ones is much less time. This time round, I am considering building from scratch, probably using parts from marchant dice, but even my initial cost estimates are rather scary. I have already bought the parts for one axis, and while they are of lovely quality, they did cost more than my manual X1!
    I am also more electrically than mechanically skilled, and so am finding the prospect of building from scratch a bit daunting, but atleast I have a CNC mill and a lot of software to help me cut parts for the new machine - do you have access to the tools you'd need to make your own mill?
    I'd also recommend that you budget at least 300-500 Euros for tooling - vices, collets, mills, measuring devices etc eat up cash like you wouldn't believe!
    Also if you're going to be doing a lot of aluminium, you should probably consider a coolant system - this means an enclosure, which is a whole other adventure!
    Best of luck, whichever way you go!
    Nov 2006
    Greece
    Many thanks digits for the very informative reply. A CNC mill is almost essential for those of us who need to make high quality custom metal parts/panels for projects, etc., but can be very expensive to build from scratch as you say. In terms of availability of tools to make my own mill, a friend of mine has just bought a ready-made Proxxon MF70 mill (CNC'ed by a German company called USOVO) and some s/w, but he's still struggling to make the machine work (and he's more experienced than me in metalworking). Also, the MF70 may be too small for such a project... Anyway, based on your post, my best option would probably be to purchase a ready-made (CNC'ed) mill like the Sherline/Taig/Sieg/Proxxon.
    You mention about the need for coolant. The problem is that I will be using the mill inside my house (I don't have a workshop, only a small electronics lab inside the house). I watched a movie clip once showing a CNC with coolant and the thing was very messy! Do you think it'll be absolutely necessary to use coolant for aluminium parts?
    Another thing I want to ask you guys is about spindle speed. The Proxxon MF70 that my friend has bought has a spindle speed of 5000-20000 rpm. The Sherline and Taig, however, have spindle speeds of 70-2800 and 1100-10000 rpm, respectively. For the type of stuff I want to do (mainly aluminium panels/blocks and a bit of copper & plastics) what would be the most appropriate speed range? I don't just want to do engraving, I also want to be able to use a solid aluminium block and "dig" into it to make special parts, etc. Which of the main brands (Proxxon/Sherline/Taig/Sieg) would you recommend? My budget is around 2000-2500 Euros.
    Finally, about software. The name I keep coming across when searching for CNC s/w is Mach3, so I'd have to build or buy a stepper motor controller that is compatible with it. What do you guys think? Are there any other good s/w I should be considering except Mach3? My friend with the Proxxon MF70 has bought something called WinPC-NC (for driving the SMC-800 controller that came with it) and another s/w for the CAM part called Filou-NC. What about these? Are they any good?
    Again, apologies for the many questions.
    Thx guys, I really appreciate your help!
    Costas
    Aug 2006
    UK
    You don't have to buy a pre CNC'ed mill, you could buy a mill and convert it - if you can find someone who is doing packages with motors mounts drivers and PSU's, it could be a one-stop-shop, and with hindsight, I don't think it would save you all that much to shop around for each component.
    I would be a little wary of a mill that forces you to use a dedicated H/W controller - I wouldn't like to be tied in to using their software. I went with Mach 3 and I don't regret it at all - it is very easy to use and performs well, but I could just as easily switch to a Linux solution as the hardware isn't tied to any particular software.
    As for stepper drivers, I made the mistake of buying a shoddy ebay 4-axis driver board for £90ish - it caught fire when one of the motors stalled, but before that it was losing steps due to thermal shutdown - and at half its rated current with additional fans and heatsinks Anyway, I got myself some excellent 4.2A drivers from Motion Control Products for about £35 an axis - I should have got them in the first place when I bought my motors from them! Anyway, they are a breeze to wire up - they have optoisolated inputs, so all you'll need to do is wire them to a parallel port connector and add a PSU.
    You don't have to use coolant - but you will forever be brushing off chips and spraying on WD40 as it runs to keep the cuts clean. I lasted about 5-6 weeks before I gave in and built a (hideous) coolant table - my mill is so slow that I don't want to have to stand and watch it for 2 hours with eye and ear protection on! The cuts are much cleaner and quieter too - and as I'm in a 1st floor apartment, that matters to me and my neighbours!
    My mill tops out at about 2000 rpm - which isn't really enough for aluminium with small cutters, and it's too weedy for big cutters. I am aiming for about 4k rpm on my next machine, but IMHO, even that's too slow for engraving.
    Hope that helps and sorry about all the waffle!
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    I can give no advice on these machines, but a 6mm carbide cutter should be running 10,000 RPM + in aluminum for best efficiency.
    www.integratedmechanical.ca
    Nov 2006
    Greece
    Smile Thanks!
    Thanks again digits, that really helped a lot, I appreciate it.
    OK, so I'll have to get a manual mill and CNC it. This would mean properly attaching the 3 steppers to the three axes. For the controller I'd also want something open (non-proprietary) and compatible with Mach3. I've heard there's also a Linux CNC s/w called EMC that was ported from a US military project. This may also be a good choice. In any case I want to steer clear of proprietary controllers & s/w. My friend has paid more than 300 Euros for what I would call average-quality s/w, only to find out that he now has to pay another 150 Euros to upgrade to a different version!
    The difficult part right now for me is to find some shop/company in Greece that can do the modifications on the manual mill. Will try Google but I have the feeling it won't be easy. Fortunately I live in Athens, hopefully I'll be able to find someone who can help. I might even try to use my friend's mill to build some parts myself. If that fails, I'll get a pre-CNC'ed mill.
    Will post here once I have something going.
    Many thanks to all for the many posts in these forums.
    Costas
    Aug 2006
    UK
    Quote Originally Posted by DrCNC View Post
    Costas
    For what it's worth, my CNC conversion was from www.cncfusion.com - it was a simple bolt on job - no tools other than an allen key required! I'm pretty sure that if you have a look on the net, you'll find something similar somewhere.
    Best of luck
    Nov 2004
    scotland
    for cam software have a look at the excellent cambam
    the guy that codes it is on here sometimes
    it works and is free (at the moment anyway)
    get a cheap autocad lt package and for most 2/2.5d stuff they're all
    you need www.brusselsprout.org/CAMBAM
    oh and deskengrave http://www.deskam.com/deskengrave.html
    mike
  • Posting Permissions
