Holy #$%#$%!!!! Have you all seen this?? http://www.littlemachineshop.com/pro...ProductID=2936 http://www.littlemachineshop.com/pro...ProductID=2937 -Jeff PS: I searched cnczone to see if anyone mentioned this, and they haven't yet. |
How hard would it be to make a powered drawbar with a meaty stepper motor? |
| CAD drawings only. Why no photos. At what stage of development is it. Is there a running example. How about a video. Its backordered so who out there has one. On sale as well. My sceptical nature must be showing by now I guess. Regards Phil
| Looks like the power drawbar/tool changer costs more than the mill. Go figure! Don't forget the $$$$ for the Tormach tool holders. Guess I need a second (or maybe 3rd) job! Bill
__________________ billyjack Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>) |
#10
I hear that! Do you think a stepper might be up to doing the drawbar? I'd rather it were screwed in and out than just pulled back in by a spring... |
#11
| from the looks of it i would say that the drawbar itself is springloaded and that is a fat air cylinder on top of it. i have been wanting to build something similar, but i just haven't put down the cash for the tormach tooling yet.. maybe someday, just not today. |
#12
| I think the main issue is that the driver needs to be disconnected from the draw bar when the spindle is rotating. This is easily done with a spring and air cylinder. It becomes mechanically more complex if you want to - connect to draw-bar, rotate, then disconnect. Of course it is doable but coming up with a simple reliable mechanical system will challenge your design skills. The down side of the air cylinder/spring arrangement is you need a compressed air supply and, unless you complicate the design, the considerable force require to compress the spring when releasing is taken on the bearings. I guess you could replace the air cylinder with a stepper motor combined with some kind of a cam/lever arrangement in order to gain the considerable mechanical advantage necessary to compress the spring. But that still leaves the spring. Regards Phil |
