Results 1 to 9 of 9
Thread: Mini mill base/xy table question
    Oct 2006
    I recently got a great deal on a mini milling machine with a ton of goodies with it. The only minor issue that it does not have a base/X-Y table. Little machine Shop is backordered and I am waiting for a reply as to when they may have them back in stock. Would it be possible to get a flat steel plate such as 3/8" thick and then bolt the machine down to it with 123 blocks. Then bolt down a table such as this
    http://cgi.ebay.com/COMPOUND-SLIDE-M...QQcmdZViewItem
    or
    http://cgi.ebay.com/6-HORIZ-VERT-ROT...QQcmdZViewItem
    in front of it? Hopefully that makes sense to some of you folks that run mills. If not I can re-explain it. Thanks for any help you can offer. akraven
    Jan 2006
    Bad Idea
    Either of those would not seem to work. Could you explain more what you bought or could you provide a picture(s). If you can purchase the new upgraded table for the mini mill. Thats what the post about the MY CMPLETE X2 SETUP is all about. Its discussing the pro's and cons of the x2 if that is what you indeed have.
    Oct 2006
    I have the head and column but not the base or x-y table. My column looks like this http://www.littlemachineshop.com/pro...ProductID=1766 with that green bracket on the bottom where the 3 bolts go. The previous owner sold off the base and x-y table like this one http://www.littlemachineshop.com/pro...ProductID=1765. Hope that makes it clearer. akraven
    Nov 2005
    Alabama - USA
    Try looking asking here New X2 Mini Mill Base
    You could buy one of these or maybe get someone who is buying to sell you their base.
    Mike
    Oct 2006
    Thank you for the info Mike. That base is a little out of my range but the idea of finding someone who bought one and wants to get rid of the old one sounds good. Thanks again. akraven
    Nov 2004
    scotland
    doing what you suggest in post 1 will work fine
    http://www.pathcom.com/~vhchan/cnc/cnc.html
    this may inspire you.
    mike
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    Oct 2006
    Thanks Mike Jeffers that is exactly what I had in mind! I will bookmark that for reference. Thanks again. akraven
    Oct 2006
    Switcher those look great. If I can find a US source with that much choice it would be great. Shipping from the UK would be a bear ! Thanks akraven
  • Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
