Old 09-28-2006, 03:10 PM
jhwatts is on a distinguished road
Backlash Problems
My benchtop mill is experience some bad backlash. Can anybody give me any good ideas on a quick and dirty way of reducing it?
Old 09-28-2006, 06:19 PM
philbur is on a distinguished road
One good method is to investigate the problem then fix it.
It’s like saying my automobile won’t go how do I fix it. You need to take the trouble to give some background/details if you really want some help. Otherwise the silence could be deafening.
Regards
Phil
Old 09-29-2006, 06:42 PM
NC Cams is on a distinguished road
Check out these links:
Ball screw backlash:
http://www.thewarfields.com/MT/CCBacklash1.htm
http://www.thewarfields.com/MT/CCBacklash2.htm
http://www.cnczone.com/forums/showthread.php?t=25181
You're categorically dreaming if you think machining problems can solved by the application of "quick and dirty" methods.
Quickest and dirtiest method I know of is to buy a great, tight machine in the first place.
Otherwise, you slog thru each and every part, find the problem and then solve them bit by bit, piece by piece.
