Old 09-18-2006, 12:30 PM
RLC RLC is offline
RLC is on a distinguished road
Mill Coversion, Plan or Plague?
Hey Guys,
New here, so I hope this is the right place to post.
I currently have a RF31 (round column) Mill/Drill with an off the shelve CNC kit. I went this route 1st (a) bolt it on and go (b) technical support (c) wasn’t sure if I would keep the mill or buy a bigger one. After 2yrs I have found that the round column is not a problem for me, how ever, 2amps and small steppers (260 oz/in) is. I have decided to “Roll my Own”. After countless hours of reading on the web here is my plan.
(3) Gecko G202 Drivers > Geckodrive
(3) 640 oz/in Steppers (sealed) > Campbell Designs
(1) Breakout – Combo Board > Campbell Designs
(1) Mach 3 software > Artsoft Software
(1) 48vdc ~ 15amp power supply > Transformer Technology Inc.
(extra amperage is for 4th axis down the road)
(1) I-Pac keyboard emulator > Ultimarc
(A) 0.875” Ball screws on the “X” & “Y” > undecided on a vendor
I’m in the process of building a stand from 2” sq tubing to support the machine then adding an 11ga pan and sides for flood coolant (similar to the Tormach stand) then off to have it powder coated. I constructed an aluminum enclosure that houses the PC, 15”LCD monitor, USB mini keyboard and Joy Stick. There is still plenty of room in there for the other items listed above, I’m hoping with shielded wire and good placement of components that this wont be a problem (electrical noise). To the left of the monitor is panel 6.25” wide by 17” tall to add buttons and switches and possibly an MPG down the road. There are still things that need to be worked out and/or purchased, but I believe these will be minor hurdles. Sorry for such a long post but I wanted to paint the best picture I could so that anyone wanting respond would have a better idea of what I was doing. I’m sure there are other products out there that would cost less, but these guys seem to go the extra mile to help out.
Robert
Robert
Old 09-18-2006, 12:58 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Seems like you've got a good plan. But, I think you'll get this all done just to find that your machine is no longer rigid enough.
I'd consider starting with a CNC machine with a dead control. Then you already have the large steppers (or servos) and ball screws. Sell yours to buy the parts you need. This one just went on ebay last week:
http://cgi.ebay.com/Bridgeport-Serie...QQcmdZViewItem
Karl
Old 09-18-2006, 08:04 PM
Ron111 is on a distinguished road
RCL,
It does sound like you have a plan. If you like your present mill go for it. I have 1 question. How could you learn so much with out having to ask a single question? Noticing that this is your first post. I am impressed.
As you know, post a few PICs (for those of us that are easily entertained). I sure you have found the documents and articles for building your power supply and for connecting steppers and other stuff. We have not had a good thread about CNCing a RF-31 in a while and I as well as others certainly will enjoy following your progress.
After reading you post again, it sounds like you had already cnc your machine once and are upgrading to a stronger drive system.
Well welcome to the forum!!! and do share your conversion with us. Look forward to seeing it go together!!
Ron
Old 09-18-2006, 08:23 PM
ViperTX is on a distinguished road
Welcome RLC, depending on which part of the country you're in....I would look at getting a VMC or other CNC machine with a dead controller as Karl_T stated.
Old 09-18-2006, 11:34 PM
RLC RLC is offline
Finding a good used machine isn't an option for me..Texas is a big state I live as far south as you can get, there are some machines coming out of Mexico that I have looked at but most of them are in really bad shape (I have seen as much as 75 thou or more backlash). I read alot of posts about the round column, but I like the fact I can swing the head out of my way for set-up. I have never had to make any changes to the head once I have started a project nor have I had it Slip. There are several Mini-Style VMC out there in the $30k range that are nice, but in the past 2 yrs I only have about 70hrs total on my mill/drill...I will try and document my progress and I sure there will alot of questions to come
Robert
Robert
Old 09-24-2006, 11:23 AM
RLC RLC is offline
I've up loaded a few photos of the coolant tub. here is the link (maybe)
http://www.cnczone.com/gallery/showg...ser/16333/sl/r
They are in members galleries
Robert
Old 09-25-2006, 11:20 PM
RLC RLC is offline
Got my motors and break out board in today, Geckos and power supply should be here with in a few days. With the plug and play assembly of PC's my control panel so far was really easy..now the "Plug and Pray" starts. seems there is alot of wiring that needs to done...hopefuly no "Magic" smoke will come out. I'm also posting a bearing support design in the photo gallery to see what you all think.
Robert
Old 09-26-2006, 08:56 PM
Saw the bearing block with the angular bearings and thats the way to go. Have you worked out your preloaded ballnuts yet? Lots of details, but your clipping right along.
Ron
Old 09-26-2006, 09:44 PM
RLC RLC is offline
Ron,
haven't even checked on that yet, I knew the bearing / supports it has from the factory are junk as far as trying to remove any play in the screw. And 3 bearings on 2 screws wasnt going to work either. Like I mentioned earlier the mill has a cnc kit on it now (way too slow, 10ipm). I'm working on the coolant and the new controller. will get the coolant up and going with the old sytem to make the new parts needed
Robert
Old 09-26-2006, 10:09 PM
RLC RLC is offline
I was wondering on the coolant pump if your could use a Cartridge type Bilge for the boating industry? They generally live in some pretty rank conditions and and can pump 800gph? The cartridge is cleanable as far a debri getting into it.
Thanks in advance
Robert
  #11   Ban this user!
Old 09-29-2006, 12:03 PM
kochevnik is on a distinguished road
Keep in mind, the Gecko 201 and 202 series are 10 microstep drives. For example on my machine, I use 200 steps/rev steppers (standard) and a 20 TPI screw. The parallel port gives me about 16000 Hz under turbocnc. So 16000/(200 * 20) means 4 inchs per second (240 IPM) MAX for full step drivers. If I would be using a Gecko 202 like you, the max speed I could get would have to be divided by 10 (microsteps) giving me just 24 IPM MAX speed.
201 & 202 - very accurate/smooth but not very fast
210 & 212 - more choices between speed and smoothness
YMMV
  #12   Ban this user!
Old 09-29-2006, 05:23 PM
project5k's Avatar
project5k is on a distinguished road
way south texas huh?!?! im in seguin, not all the way to the bottom, but close enough... just thought i'd give you a howdy and a wave!
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
