Old 09-11-2006, 02:08 AM
ata's Avatar
ata ata is offline
ata is on a distinguished road
Question Unknow Hangzhou Westlake
I will modify a milling-machine from hangzhou westlake to cnc but i dont know how. Anybody know milling-machine from hangzhou westlake model ZX7016? I have pic but i dont know how to upload the pic here.
Old 09-11-2006, 04:03 PM
titoniks is on a distinguished road
This?
Tito
Old 09-11-2006, 06:48 PM
ata's Avatar
ata ata is offline
this is Westlake ZX7016.
Old 09-11-2006, 07:36 PM
Pres is on a distinguished road
http://www.znjs.com/trade/Electric%2...ols/ZX7016.htm
Interesting:
They show the ZX7016 with a 2 slot table but your picture shows a 3 slot table?
Is your table size 420mmx152mm?
Also, they make no mention of X-Y table axis travel.
Do you know what yours, or theirs, is?
Good luck,
Pres
Old 09-11-2006, 11:23 PM
ata's Avatar
ata ata is offline
This is Drill/Mill-ing machine from Hangzhou Westlake model ZX7016. They have 3 slot table. Dimension of worktable surface is 430x200 mm.
Tito:
Iam newb, would like to know what is that? -->
Thanks.
Ata.
Old 09-12-2006, 01:20 AM
ATA,
Apparently, you know something the factory does not know about their machine tool.
Their website gives a table size of 420mmx152mm for the ZX7016. (read it).
But you state your ZX7016 has a table size of "430x200 mm".
Are you sure you have a Drill/Mill-ing machine from Hangzhou Westlake model ZX7016?
Also, their picture CLEARLY shows a 2 slot table, not 3!
Lastly, the picture you provided http://www.cnczone.com/forums/attach...1&d=1158032113 appears to be a heavy duty dual-screw Z axis driver with a digital scale position feedback.
It looks plenty rugged for Z axis movement.
(dual lead screw is usually just needed on a big x axis)
Can/will you determine the disparity between the factory specs on their website and your ZX7016?
Can/will you give the ZX7016 X-Y axis travel (since the factory does not provide that information)?
Old 09-12-2006, 06:48 AM
ata's Avatar
ata ata is offline
Bellow are from the Drilling and Milling Machine Model ZX7016 Operation Manual:
Max. Drilling 16mm
Max. Face mill 50mm
Max. End mill 12mm
Travel of Spindel 115mm
Spindle speed 12
Distance spindle axis to column 240mm
Distance spindle nose to table 7-307mm
Travel of spindle head 300mm
Working area of table (LxW) 430x200mm
Travel of table (LxC) 236x128mm
Motor 550W
Overall dimension (LxWxH) 856.5x715x967mm
Net weight 170Kg
Old 09-13-2006, 11:54 AM
szcharle is on a distinguished road
haha Hangzhou ZX7016 ,it's made in China
the Fty website current no ZX7016 now, I only find this
http://www.westlakemachine.com/product-DandM(eng).htm
click on ZXJ7016 pic will open a detail of this mill
Max. dilling capacity ……………………………………16mm
Width of face milling……………………………………50mm
Diameter of vertical milling……………………………12mm
Spindle travel………………………………………… 115mm
Distance spindle axis to column surface………… 240mm
Max. Distance spindle nose to worktable………… 360mm
Spindle taper………………………………………………MT.2
Spindle speeds rang………………………… 365-3150rpm
Spindle speeds……………………………………………… 5
Dimension of worktable surface…………… 430Χ200mm
Travel of worktable…………………………… 236Χ128mm
Overall height………………………………………… 967mm
Motor………………………………………………………550W
G.W/N.W…………………………………………… 225/175kg
Ship measurement ………………………… 97Χ56Χ94cm
Old 09-13-2006, 12:04 PM
hi,ata will you use this 115 mm for Z axis? enough or not for you?
and titoniks
i read you pic , you have a finished Y axis stepping motor conversion?
if possible, can i see detail pic or design , i am interesting on the connection between the origin Y axis and stepping motor(gear or belt?and how?)
Old 09-13-2006, 05:54 PM
i used belt for all 3 axis
for Y axis i have mounted the pulley on the hand wheel
Name:	Meccanica asse Y.jpg‎
  #11   Ban this user!
Old 09-13-2006, 05:59 PM
Tito:
Thanks.
Ata.
the first is a digital scale
the second is a ER25 collet holder
  #12   Ban this user!
Old 09-13-2006, 06:53 PM
ata's Avatar
ata ata is offline
Yes, enough, I use to mill small piece of alu with max high only 100mm.
Do you know whatfor is this? -->
