Old 08-18-2006, 02:36 PM
Burn is on a distinguished road
IMService Kit Requirements
Hi All,
If I were to buy the 4-A 4-axis kit from IMService (http://cadcamcadcam.com/index.asp?Pa...ROD&ProdID=131), Can someone give me an itemized list of everything else I would need to buy to complete the setup? The people there have been of no help at all and I am turning to you guys for the help I need.
Thanks a bunch
Burn
Old 08-18-2006, 04:54 PM
turmite is on a distinguished road
I'm gonna say this knowing full well I make take a flame for it.
If they have been no help..........why are you looking there? I'm not going to recommend anyone, but take a hard look at the advertizers list here on the zone. You will find there is a full menu.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 08-18-2006, 05:00 PM
Thanks for the thoughts, I appreciate them.
I chose these guys mainly because they included just about everything I would need (hardware-based) except for a couple things...I found that it would be a bit easier ordering from them if I had a basic idea of what I would need to buy additionally.
I also like their servoes- They seem pretty powerful.
If you have the time, would you mind reccomending some other manufacturers of a similar kit?
Old 08-18-2006, 05:44 PM
Deviant is on a distinguished road
heh,
I'm not afraid of being flamed.
What mill are you planning on cnc'ing?
Are you 100% sure you need the servos. Alot of people here are running the hobbycnc board board with 250-500oz stepper motors. There are also other stepper driver options.
That kit doesn't included the power supply, enclosure, couplers for leadscrews, mounts for the motors to mill, or the software/pc to drive them. Also, you'll have to get a rotary table that can take that setup. Or any improvements you make to the mill. ((bearings, preload washers, etc...))
874 bucks seems a bit spendy.
I guess I need to wait and see what your planned project is.
However,
You should be able to pick up 4 geckos at 114 per. And 3 500oz nema 23 steppers for 260+/-.
That's 716 bucks for what alot of people would argue is a better system. Assuming you don't specifically need the servos.
Or you can pick up a server kit from hobbycnc, currently listed at.
4 Axis 4AUPC Kit + (4) 200oz-in, 3v, 3A,
Dual Shaft Steppers
UNTIL SUPPLIES LAST
$229USD + $16 USA S/H
or
4 Axis HCNCPRO Kit + (4) 200oz-in, 3v, 3A,
Dual Shaft Steppers
$259USD + $16 USA S/H
I haven't looked at what the difference between the two kits really is. But 280 bucks looks a lot better than 874 to me.
Of course you should be able to get just the board and pick up the 500oz nema 23 motors off ebay.
And you'd still need the same parts that I listed above.
Don't get in a rush, spend alot of time reading and learning before you open your wallet. I have a good bit of stuff that I knee-jerk purchased and don't need.
Old 08-18-2006, 06:08 PM
Well, I am going to be CNCing a Taig 2019CR-ER with the ER16 spindle. Got it a couple days back but parts went back due to damage.
Money will be forthcoming sometime soon.
Taig included 3 couplers and the mounts needed- I am concerned about the mounts though, they seem flimsy. If other people are using them though I won't put up a fight.
Why did I choose servoes?
- Less heat
- More accurate
- Less lost steps than steppers
I will have the PC that will run Mach3 up in a while, I need to buy a bunch of stuff for it.
I will be milling copper and delrin mostly, I will more than likely not be machining iron.
Thanks for the help so far
Old 08-18-2006, 06:14 PM
Gold Member
imserv is on a distinguished road
> On 8/2/06, imservice wrote:
> > Dear Corey,
> > It depends on what you already have, such as software, etc. and what you
> > are trying to do. There are pictures and descriptions of what is in the kit,
> > it may be just what you need if you have some components already, sources
> > for other parts, and have a good understanding of the mechanics, or
> > electronics to do it yourself.
> > For those that need more help, we also sell a Sys-4 that has the
> > components already assembled in a box. You should look at the difference
> > between what you get in the kit, and what you get in the Sys-4A, or a Sys-3a
> > (with software) to see what you need.
> > The webstore has some of the components not in the kit, like power
> > supply, e-stop, etc., but not all the things from the systems.
> > http://www.cadcamcadcam.com
> > Here are some links to compare, that will show you some of the
> > things you need in pictures and descriptions , and some have lists of the
> > parts:
> > Sys 3A list:
> > http://imsrv.com/deskcnc/system.html
> > Kit 4 A list
> > http://www.cadcamcadcam.com/index.as...PROD&ProdID=71
> > http://www.cadcamcadcam.com/index.as...rodID=116&HS=1
> > Info:
> > *http://www.imsrv.com/deskcnc/bench_top_cnc_systems.htm *
> > NOTE: 2 pages - components purchase link
> > http://www.cadcamcadcam.com/index.as...TS&Category=16
> > http://www.cadcamcadcam.com/index.as...ATS&Category=3
> > Browse the store, and click pictures for more information.
If you have some specific questions we would be glad to help.
A minimal system requires a power supply, a kit-4, a CNC ready mill, and S&D software.
Fred Smith - IMService
http://www.cadcamcadcam.com/hobby
Old 08-18-2006, 06:15 PM
Thanks Fred- I did read that email
I guess I was looking to get more specific, down to an itemized list of what I would need to buy in addition to the 4A 4-axis kit. Take the power supply for instance- What specs does it need to have, i.e. amperage and voltage.
Thanks,
Burn
Old 08-18-2006, 06:38 PM
- Less heat
- More accurate
I'm sure someone else will chime in, but with the increased power of the steppers (200oz/500oz) there is less chance of running into missed steps. Heat shouldn't be a problem if your not abusing the steppers. The accuracy of the stepper should be good enough for the taig/mini mill. Someone with a taig, will have to provide you with the actually steps per 1inch that the steppers would provide.
I don't want to push you one way or the other.
Personally, I have a mini mill. I won 3 gecko 320's from this website in a contest. If I hadn't. I was going with steppers.
I purchased 3 250oz servos with 250 encoders for around 250 bucks. I'm building a 36v 20a power supply for it. Which is going to set me back around 100 bucks.
If I had gone with steppers, I could have used a cheaper 24v 10a power supply.
You also need to look at your budget and make sure that you have purchased all of your tools. I spent alot more for all the tools and accessories than I did for the for the mill. Keep that in mind.
As for your mounts, Taig is fairly well known and I haven't heard of any problems with their included motor mounts. I think they will be fine, as long as you don't do anything crazy.
Again, I can't stress enough. You need to decide 100% what your expectations are and how you want to get there.
I.e. 200ipm feeds and 0.0001 accuracy. I doubt you'll ever get that on the taig. Of course, I don't think I'll get it on my mini mill either.
But who knows I might be surprised at the accuracy of the taig. I looked a long time at getting one. I still do vs finishing the conversion on my mini mill.
(( Still might, just got a phat bonus..... *grins* Runs off to surf ebay...))
Old 08-18-2006, 06:43 PM
Thanks for the help
The main parts I am going to be machining aren't more than 5 inches long, but they do get detailed- Drilling holes in precise locations and such.
I would be more concerned with accuracy than speed, that's just the way I would base my decision off of.
If I do decide to go with steppers, Should I go with Xylotex or HobbyCNC?
Old 08-18-2006, 06:53 PM
Another quick addition- If I were to buy from Xylotex, I would be buying this kit- Correct?
http://www.xylotex.com/4AxSysKit-425.htm
  #11   Ban this user!
Old 08-18-2006, 06:58 PM
I honestly don't know about that one. I've had more email conversations with hobbycnc, but that doesn't mean anything when you get down to it.
I see more people here running the Xylotex boards.
I'd email both places and ask them point blank, why you should buy their product over the other. The same with IMService.
I'm not saying you need to be an a$$ about it, but your the customer and should make as an informed decision as you possibly can.
With that said. I'd look on ebay for the 500oz steppers and email that person and ask what size power supply they suggest and what driving board. If 500oz motors end up not being strong enough, dunno why that would be. You could always use them to cut new motor plates and setup a reduction pulley system to give you more power at the cost of speed. Just something to keep in mind.
That's what the IMService system is doing.
  #12   Ban this user!
Old 08-18-2006, 07:00 PM
That one would work... I don't really like the 24v 5a power supply offered. But if they are selling it as a kit, it must be working out.
Usually, I subscribe to the Tim the Toolman school of thought.... More Powah! *grunts*
But then my Woah-man, drags me back to the earth.
