Old 07-28-2006, 02:48 PM
David Da Costa is on a distinguished road
Using a Contour Design Shuffle as a pendant
Hi all,
I thought you might be interested in seeing the Contour Design Shuffle that I have setup as a pendent for my Sherline CNC Mill and lathe that I am using with Mach 3.
The buttons are fairly obvious except the one labelled XZY. This toggles the useage of the jog and shuffle wheel between each axis (a small popup on the Windows toolbar tells you what axis is in use.
The outer ring on the controller provides fast jog in each direction while the inner one provides a step by step move as you wind it around for fine movement.
The four bottom buttons are unused.
David
http://www.scalereplica.com
