Old 06-09-2006, 07:19 AM
RTP_Burnsville is on a distinguished road
X2 Stand or Bench
What have all you X2 (mini-mill) owners used for a mill stand or bench that works well? My first attempt of using standard industrial steel workbench legs, 2x6 framed top covered with an additional 1 1/2 inch laminated top did not work well. The steel legs had a bit of spring in them which did not make for a solid stand even with lots of steel and wood cross bracing. Any ideas before I run off to the lumberyard for a load of 2x lumber. Thanks
Old 06-09-2006, 07:42 AM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
http://www.mcmaster.com/
search for Steel Tables, they have an enormas selection!
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 06-09-2006, 09:44 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Or fire up your welder:
http://www.thewarfields.com/MTWeldingMillStand.htm
Best,
BW
Old 06-10-2006, 04:53 PM
Nice metal stand..... However, I currently don't own a welder. I wonder if I were to build a similar one from wood if it would be stable enough? Thanks for the link.
Old 06-10-2006, 05:50 PM
ZipSnipe is on a distinguished road
For the x2 you could definetly do one out of wood, I would go with 4x4 post for the legs, wood glue plus screws and nails on all connections, if you search thru this forum I think someone put up a thread on benches and check out some of those designs. I found for the sturdyness to wrap at least three sides with plywood, the top would be a minimum 3/4" plywood, on the sides you could do 5/8, for the legs you could tilt them out at a slight angle( kinda like they do most stands anyway) but being its an x2 as long as your footprint is like 36 x 36 you could leave straight vertically. Just search for benches on this forum, you,ll get some good ideas.
