The motors just need to have a shaft coming out of both ends. One end will connect to your screw and the other gets a handwheel on it. You may have to piece together the controller and motors from different vendors to get what you want. If you want to use the mill manually just turn off the power to the drives and use it manually.
LinkBack URL
About LinkBacks
JRouche
