Results 1 to 7 of 7
Thread: X3 Z-axis conversion
    Jan 2006
    I am planning on converting the Sieg X3 to cnc but I have a question. The primary use of this machine is 2.5D milling, not full 3D milling.
    My question is, how bad of an idea would it be to mount the Z-axis stepper where the original Z-axis dial is located. I am sure some backlash will be developed but how bad do you think it would be?
    The dial is mounted to a shaft that uses a gear to turn the Z-Axis leadscrew.
    Attached Thumbnails Attached Thumbnails X3 Z-axis conversion-g0463.jpg   X3 Z-axis conversion-dsc02541.jpg
    May 2003
    Z-axis
    bigvinney,
    I am in the process of converting mine right now. I thought the head was heavy enought to keep backlash manageable, but I wanted to do contouring and thought the cutter may bounce itself and introduce chatter. My mill didn't have the dampening cylinder. I took the whole assembly out and made new bearing blocks. I didn't want to machine the cast pieces. I am mounting the stepper on top of the column and using the hole from the handle bearing block for wiring and oil lines. I made a stand and will eventually have an enclosure so I can use cooling. Anyway, this is the way I am doing it, I didn't want to get it finished and then find out I should have done it.
    Carvejunky
    Jan 2006
    Thats what I was thinking to, so I will probably make something like the one from www.cncfusion.com and mount the stepper in the lower backside of the column.
    May 2003
    Bigvinney,
    I had not seen that before... very nice. I did mine quite a bit different than how he does that. I wanted to get as much X and Y movement as I possibly could so I mounted my ballscre nuts differntly and actually spaced the stepper mounts and end bearing mounts further apart. I was kind of hesitant to write because I did mine so different from what I have seen. I am going to use mine for roduction so I have double ballnuts on all the axis and really stretched the X & Y. Glad to help tho...
    Carvejunky
    Jan 2006
    DO you have any pictures? I would like to see how you set it up.
    May 2003
    Pic's
    I don't have it all assembled yet, but I will send pics, or post them as soon as I am done.
    Carvejunky
    Nov 2005
    U.K.
    X3 Z axis conversion
    The drive from the z axis handle is via the bevel gears which are not (as supplied ) adjustable so the backlash would be significant. I've just mounted my motor on top of the column after drilling a hole in the top with a hole saw. I still have backlash of about 0.1 mm which I'm investigating. A possible cause is play in the vertical gib strips, I think this is aggravated by the hydraulic piston which acts in the same direction as the weight of the head ( pushing the the head forward and down). A counterbalance system with pulleys which would support the head weight would be better but I haven't got round to that yet.
  • Posting Permissions
