Well, I am designing my next mill right now in solidworks. Its kind of a far fetched dream, but atleast I will have a design when I have access to the tools to make it. It will be a dovetail design for simplicity, and use preloaded rockford ballscrews. Here is the base, nut holder, and nut designed soo far. More to come! Its roughly 16in long, 12in wide. |
| I modified the Z-axis, and added some bearings to the spindle, and added the internal spindle. I need to find some dimentions for an R-8 taper, so I can add that in. Anyone know where I can find it? Thanks - Zachery |
Very interesting project Will you make it yourself ? If so, what machines will you use ? |
| Although I cannot make the actual machine now, my plans are that this machine is capable of being made on a simple 2d cnc prototrak, bridgeport, or centriod. It may be possible to make on a manual with a dro, but I would say its easiest on a 2-axis cnc. Thanks for the r-8 info. I will incorperate it into my plans. - Zachery |
| Hi Zack, For the sake of simplicity why don't you just get the spindle off of a brideport series one and incorporate it into your design? They have a R-8 taper and its a proven design. You can find them every now and then on E-bay (just the spindle). |
#10
| This is supposed to be a benchtop mill, with travels around 24x12. Do you think a bridgeport spindle will be too big? I'd imagine with a quality lathe (A heavy one..no chinese 7x10) it would be easy to machine an R-8 spindle. Plus, is there any dimentions for a bridgeport spindle? I am trying to design the whole mill in solidworks. |
#11
| If you want 12" in y-axis travel, you need the head to stick out to the center of the table in the center of its travel(the center of the spindle) so it can reach its max travel. I think the base of your mill is a little beafy compared to the column and head. Slightly out of proportion ![]() Jon
__________________ CNC Mini Lathe Plans and Rotary Table kits: http://jfettigmachines.com |
#12
| for your R8 spindle, check this thread out: http://www.cnczone.com/forums/showth...5&page=6&pp=15 all about modifying the littlemachineshop R8 spindle box.
__________________ FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info. |
