Ok guys about to order one or the other and i need your help to decide what's the best unit.... The Lathemaster specs.... 6 Speeds: 110 to 1920 rpm Drill Capacity: 1 1/4" Face Mill Capacity: 3 1/4" End Mill Capacity: 1 1/4" Head Swivel: +/- 90 degrees Max. Dist. Spindle to Table: 17" Spindle Type: R8 Spindle Stroke: 5" Spindle Diameter: 3" Column: Dovetail Ways Worktable Size: 31 1/2" x 9 1/2" Cross Slide Travel: 7 1/2" Longitudinal Table Travel: 21 1/4" Motor: 2 HP, 110V/220V/60Hz Machine Height: 42" Machine Width: 46" Machine Depth: 33" Weight: 730lbs Shipping Weight: 805lbs. The grizzly specs...... * Tapping switch * Auto and manual feed reverse * Eye shield * Quill lock * 1-1/4" drilling capacity * 3" face milling capacity * 1/2" tapping capacity * Reversing switch * Direct drive Specifications: * Spindle taper: R-8 * Spindle travel: 4-15/16" * Quill diameter: 2.95" * Table size: 9-1/2" x 32-1/4" * Table width end to end (tip of handwheel to tip of handwheel): 45-3/4" * Table travel (longitudinal): 21-5/8" * Table travel (cross): 7-1/2" * Max. dist. spindle to table: 18 5/8"" * Max. dist. spindle to column: 10-1/2" * Machine depth (back of column to tip of front handwheel): 31-1/4" * Machine height 55-1/4" * Head tilt: 90º both ways * Head swivel: 360º * T-slots: 4 slots, 1/2" studs * Range of 6 speeds: 120-1970 RPM * Motor: 1 HP, three-phase, 220V * Approximate shipping weight: 625 lbs. Need some help they are both +-$50 dollars to my door so thats not a issue but tell me what one you would go with and why as always thanks guys. |
| Well I've never owned any of the Lathemaster or Grizzly mill/drill machines, but my Lathemaster 8x14 lathe is top quality. Personally I have a Jet JMD18 mill/drill and except for the round column it has been a great machine...but I wouldn't buy a mill/drill again....I'd spend another thousand or so and get a Jet mill or a used Bridgeport. |
| Lathemaster. Its got power on the Z axis and it weight 150 + lbs more. Phil
| I will now be buying the power head version of the latemaster, or i had not planed on it. Do you think it would be better to buy the power head or buy a DRO? Whats all the tapping stuff that the grizzly comes with watt does that do? |
| dont try to run a lathemaster mill on 120v the wires will be toasted in 5 months...i have this mill..i have had lots of problems with the wires ..in the process of run'n 240 to the garage to fix the problem i hope...if theis doesnt work i'm selling it and trying another company |
I have a older model of the Lathemaster mill. I have to agree with the last poster. DO NOT BUY A 110v model. I got mine that way and while it did not toast any wires I eventually converted it to 220vac. The machine comes with a large control box with the 110v model and has a buncha contactors and whatnot in there. My machine was either 110 or 220 but the thing is that mine had the power head lift and I really enjoyed it before cnc but once I went 220v I could not get the power head lift to work right again. I am sure it is something silly but I could not figure it out and was planning on the cnc thing anyways so I never bothered too much with it. If you are not planning on cnc I would definitely get a 220v model with the power head lift. THe head is really heavy and cranking it up and down is a real bummer.... As far as the machine goes, I have been VERY happy with it and now that it is cnc, it is just awesome!! I know the grizzly machine has the tapping feature and I do not know anything about it but I would probably get a nice tapping head anyways. The idea that the machine is 150 lbs heavier is also a big deal because weight is your friend when it comes to a milling machine. THey are basically the same other than these items I think... The only other real option here is to pay some considerably more money and buy an IH machine. Larger travels and some slightly nicer ground surfaces there and for cnc might be better in the long run. Travels are very important!!!! Bob Bertrand at Lathemaster has taken very good care of me even during some very frustrating times when I was trying to convert it to 220v. I am no electrician and he was patient and kind and helpful with it over the phone. He has also taken care of me long after the sale with a part I accidentally broke sending me one for free real quick.... Super nice fellow...peace |
| One question, who makes lathemasters machines for them? I'm guessing most of these machines are made by the same company just like the smaller mills and lathes. I would be willing to bet that the quality is same between the two your looking at with just a few different features setting them apart. As for which to choose, Nether! I have my eye on the Grizzly G0484. It's just a few bucks more and has a power Z, more HP, and a lot more cast iron. Just another option. Happy shopping! Dale P. |
#10
It is basically the same machine as the others but it comes with the stand. It also comes with a considerably slower spindle speed and it comes with a power feed on the X axis. To be honest if I was gonna spend that much money I would definitely get the IH machine. YOu can always pick up a power feed unit off ebay or whatever. The near 2k spindle top speed while noisy with the gear head comes in handy for aluminum cutting.. This is why I say that the LM machine seems to be a very good value at it's price point, next step up is the IH followed by a Knee mill.... WIsh there were other options but not so far...peace |
#12
| The G 0484 has the same spindle speed as the one your looking at. I work with mostly aluminum too so I need the high speed too. It has 1970 RPM and a power feed on the column as well as the table, weighs in at 930 pounds and comes with a larger motor as well as the stand. I know I can get a very used Bridgeport for $2000.00 but I would think repair costs would be a lot higher on a machine of that size verses this one. I also don't have room for a full sized machine. Not to mention most full sized machines need three phase power so a phase converter would have to be figured into the costs too. What is the price for the lathe master or IH mill? I will have to keep them in mind when I buy my new mill. I'm still interested to know who is actually making these machines. Dale P. |
