Old 02-08-2006, 09:24 AM
Smertrios's Avatar
Smertrios is on a distinguished road
Can you make a better low cost CNC mill?
A CNC ready TAIG mill is about $1000.00
Xylotex "4 axis box" ready to go with steppers about $600.00
Mach2 licence about $160
$1760.00 a little more if I get a mill with ER-16 spindle
FYI there are 425oz steppers available on EBay (size 23). I thought these could add another 160oz of torque for faster feedrates and rapid moves over what comes with the Xylotex "box"
http://search.ebay.com/search/search...per&category0=
Old 02-08-2006, 10:08 AM
rcazwillis is on a distinguished road
I did not think I needed new motors until I saw the price. Two new motors on the way!
Old 02-10-2006, 08:42 PM
Gold Member
ignatz is on a distinguished road
What are your parameters?
I think this might be a better low cost setup:
HF Minimill - $375 (In Store, On Sale with coupon.)
HobbyCNC 4-axis kit - $400 (Including PS. You build it.)
X2 CNC conversion - $325 + $225 for ballscrew upgrade.
TurboCNC - $60
MeshCAM - $150
$1310 ($1535 with ballscrews)
If you design/build your own CNC conversion you might be able to save a few more bucks. You could also only choose the 3-axis kit to save more money.
Old 02-10-2006, 09:01 PM
Zippi is on a distinguished road
If you go the HF Mill route, you also end up with R-8 tooling- more choices, better availability, can use tooling on future machines.
Something about those Sherlines never thrilled me- all that ALUMINUM!!! I like my cast iron 150 lb 'lil one...
Old 02-10-2006, 10:03 PM
mgamber is on a distinguished road
TurboCNC - $60
MeshCAM - $150
The TAIG is NOT a Sherline, not even in the same league. It is also VASTLY superior to the X2 mill. I have owned both and I can tell you the TAIG is more rigid than the X2. Also more accurate, more travel, better spindle, better collet system (ER16), better screws... Just simply a better machine.
Old 02-11-2006, 08:02 AM
My apologies, I lumped them together for some reason... Must have been the ALUMINUM TABLE!!!
Let's see... Bang for the Buck... Taig CNC Mill versus my Retro'd X2.
Taig, 65 lbs manual, 85 lbs CNC'd. X2, 150 lbs manual, ?? CNC'd.
Taig CNC Mill, 30 IPM rapids. My converted X2, 240 IPM rapids.
Taig step resolution, .000125", my step resolution, .000100".
Taig structure made of steel and aluminum, mine, cast iron.
Taig has "Rigid tubular steel base and column", mine, cast iron.
Taig has "hard anodized ALUMINUM table", mine, cast iron.
Taig spindle speed, 1100 to 10k RPM, mine, 100 to 4k rpm.
Taig spindle, 1/4 hp. Mine, 4/5 hp (some say they're overrated, so I'd let you call mine 1/2 hp).
Taig Speed Control, 5 groove pulley, fixed speeds. Mine, two groove pulley, electronic variable speed (I've been leaving it on the higher speed pulleys and turning the knob to the RPM I want).
Taig has LEAD SCREWS, my conversion has ballscrews and preloaded ball nuts.
Taig has 200 oz/in steppers, mine has 640 oz/in steppers.
Stepper Drivers: Taig uses ???, mine uses Geckodrives.
Taig uses "light switch" for power behind the head (that's just funky!), mine has "slam" e-stop switch on the side of the head.
Taig uses proprietary taper spindle, mine uses R-8.
The ER-16 is an added ($$$) option! With R-8, I have all KINDS of options. The truth is, an R-8 spindle wouldn't FIT the HEAD on the Taig Mill. ER-16 on an R-8 spindle? Try this: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7589817323 - it'll probably go cheaper than the ER-16 upgrade for the Taig.
Even IF you did your own stepper motors and drivers on a Taig, it wouldn't perform as well as my setup. PERIOD!!! To start, you'd have to put in 5 tpi screws!!! MORE $$$! Might as well go with ballscrews to match mine, eh? $$$...
Sure, a Taig might (and I only say that because I haven't seen them!) have better screws than a stock X2, but my retrofit cost included BALLSCREWS for my X2.
My setup was $2300, $2400-ish, a Taig CNC Mill (I'll call it "the Taig way") will run you $2155 with the ER-16 option.
You COULD get a Taig to perform as fast as my X2, but it's going to cost you more money and time. And then, you still have a Taig..... LOL!!!!
mgamber, you're comparing a CNC'd Taig to a MANUAL X2 you had, at LEAST by virtue of not considering ballscrews as part of an X2 conversion (that is, if you ever even converted your X2)...
I'm not a Taig fan, not at all... The design seems very "slapped together". They used aluminum for the table because it's cheap and easy, not because it was the best available material. They used a lightswitch for power because it was cheap and easy. Just two things that stand out. And why a proprietary spindle? TO MAKE YOU BUY MORE TOOLING- that, or it was easier, take your pick. The first time I SAW a Taig product (Lathe) was in some hobby catalog. I looked at it and thought, "What the heck is THAT? It's a MESS!". And the price for what you get? "What a joke!". And the price of the accessories? "You've got to be KIDDING!".
Taig may have been a nice product when there weren't so many competitors, but times have changed and the product hasn't.
IN ALL, ignatz' example is the most economical, I'd consider my setup a little higher priced than most would like, and Taig isn't even on the list.
Old 02-11-2006, 08:45 AM
Gold Member
JFettig is on a distinguished road
Zippy, you cant quote a cheap setup then give examples from yours. that 240ipm range is quite out of the picture for 99.9% of the people.
Overall, they both have their advantages. main ones for taig is that its a pretty good machine, ready for cnc and someone to back it up if something goes wrong.
Honestly, I think the x2 sucks, it has so little travel, not rigid, impossible to tram the column(Im not saying taig has any of these features) and the motor is way under powered(again, not any better with taig)
Me personally, I would go the x2 or acutally x3 route, thats because of my constraints and becuase I like to make my own retrofits, but its not always the same situation for everyone.
OH YEAH lastly, theres NO way that those steppers are 425oz-in! thats not even reasonable! before them there wasnt even 300oz-in motors around(295 available). Lets be reasonable, the likelyhood of them being properly labled is VERY low.
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
Old 02-11-2006, 09:10 AM
Hey Jon,
I can't? I figured well, mgamber said "Vastly Superior", and the Taig CNC'd w/ ER-16 is $2155, so I thought I'd have a go at it... That statement struck me entirely as too ludicrous to let go of...
NONE of these machines are a (name your favorite big mill here), and I'm sure any one of those "big mill" guys would be happy to come in here and laugh at this hysterically.
But, I'd be hard pressed to find a mill like this I can pick up.... LOL!
You CAN tram the column (square it to the table) if you shim the mount (tram it front to back and shim, then left to right, then re-check). I've seen a few methods for strengthening the column, angle iron, concrete...
Take Care,
Paul
Old 02-11-2006, 09:43 AM
Smertrios's Avatar
Zippi do you use Gecko 201's?
nevermind found my answer...
http://www.cnczone.com/forums/showthread.php?t=13799
Old 02-11-2006, 09:49 AM
Yep, sure do! 3 G201's and a 48v 15A Switching Power Supply (no external capacitors). I'm running these motors at slightly less than the 5.5A they're rated for (current set resistors I had available), and using the "power down when idle" mode on the G201's. I tuned the potentiometers on all of them for smooth running at low speed.
  #11   Ban this user!
Old 02-11-2006, 10:10 AM
At least it is a STRAIGHT ALUMINUM TABLE unlike the .007" warped on on the X2
OK, Lets compare MY Taig CNC...
Fill the column with Concrete... Bolt it to a big ol piece of iron... Weighs more than the X2...
My belt reduction gets me 90ipm. SMOOTHE 90ipm. Most X2's would self destruct at that speed. I had to get the dremel tool out and grind on the way surface to even get the massive 4" of y travel on the X2. Ya quality product there...
My step resolution 0.00003125. Big deal.
I'll give you this. Wish they would make the saddle and table out of cast iron. But make it Quality cast iron that is STRAIGHT and smoothe unlike the X2.
Mine: ~200 rpm to 13,500 rpm
1.5hp treadmill motor. Computer controlled spindle speed.
Ummm... Don't you mean gears? PLASTIC easily stripped gears?
Mine: 7/16" precision leadscrews from Kerk. .0001" over 12" error. Zero backlash, self lubricating.
Gecko 320.
Big red E-stop on my controller.
You can get the mill with the ER on it, not that much more.
Whatever.
Mine is better than yours Na Na Na Na!
Now see here is the problem with your argumnent. You admit to having no experience with a TAIG.
The TAIG is smoother, more rigid (There, I said it! I could deflect the column on the X2 MORE than I can the TAIG by pushing on the spindle, measured it with a last-word indicator.) Cast iron is great if designed properly. The x2 colum to base is WEAK. The TAIG has way more travel (4"y vs. 5.5"y, 8"x vs. 12"x, 7"z vs. 6"z, your gonna need that extra Z to get that massively over size collet system for such a small machine out)
Oh, mine cost more than that, but it is all in the control, also didn't spend any time with a file on the TAIG to get it to actually travel the advertised distance.
Dude, you are really over the top here.
Screws are not the issue. Crappy built quality is.
Brass tapered gibs vs steel gibs that look like they were cut with a hack saw... Machine ways that look like they were fly-cut with a dull cutter, weak column to base construction... I can name as many bad points of the X2 as you are the TAIG.
Ya, not changed at all (Box ways vs the old dovetail, er16 spindle vs old proprietary, 1/4hp vs old 1/8hp... Dude you don't know what you are talking about here.)
The thread started off discussing economical. You started arguing "better". The X2 is not the best out there. The TAIG is not the best out there. They both have strong and weak points. The TAIG will work better out-of-the-box than the X2, no question. Your retrofit seems to be pretty cool, but there are a lot of pretty cool home built conversions.
Old 02-11-2006, 10:20 AM
Gold Member
hey, lets see who can piss farther....
mgamber you got a pm(speed controll)
Jon
