Old 01-25-2006, 09:08 PM
impact is on a distinguished road
Changing Collets
Bit of an embarassing question but how do you go about inserting and removing collets?
I am running a taig with an er-16 spindle.
Old 01-26-2006, 01:47 AM
phil burman is on a distinguished road
First you insert the collet into the closing nut. You push it in at an angle and it will snap into the holding ring. Then you insert the collet/nut into the collet holder. Removal is the reverse. I have to admit I had the same trouble when I first used it several years ago.
Best Regards
Phil
Old 01-26-2006, 07:49 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
If it helps, I think we all have had that problem at some point.
When I change out collets, I have a small (tapered) cone shaped plastic thing, about the size of my collet, I press the plastic cone onto the collet by hand, and seat into the collet holder. Removal is the reverse. Its a snap!
