#13
| Mark, I've got a Taig 2019CR and I would strongly recommend it for your needs. The max travel of 12 x 5-1/2 is well larger than what you need for your parts. You could easily build one up for CNC for less than $2000. Everything just bolts right up. I run rapid traverse on my machine at 108 ipm and have cut slots in aluminum with a 3/16" cutter at 18 ipm. You can get a lot done here for not much money. This morning I was machining a part very similar to what you described. I milled a logo in a piece of aluminum 0.040" deep with an 1/8" cutter. Took maybe ten minutes at a pretty conservative feed rate. The finish was beautiful. I just ran steel wool across it a few times and I was done. You could probably run a Taig at 30 ipm cutting acrylic. Send a post back or PM me if you have questions. Scott |
#14
| If you are interested in going the Taig route, I have one that is just gathering dust since I got my Tormach a couple months ago. I bought mine from Denver CNC, so I have their Xylotex based 4-axis controller. It's been upgraded to the 1/4HP spindle motor and 280 oz/in stepper motors. I've never run mine much above 30 ipm, but I'm sure it would go a bit more. I'll throw in all of the Taig tooling I have, fly cutter, 5 of Nick Carter's tool holders, drill chuck. Also included is an old Trico Micro Drop Coolant system (less mess than flood or mist) that I picked up on Ebay for $160. It leaks a little, but it still works fine. Oh, and the 48x24 enclosure I built from 80/20 quick frame and 1/8" plexi goes too... I'm looking for around $1800 for everything... If you're in Pittsburgh, I'm only a 3 1/2 hour drive away in Harpers Ferry, WV. Let me know, Dave |
#17
| Well there is a big difference between a mill and a router...the mill is generally sturdier and the router generally has a larger envelope. I would look at picking up a used Bridgeport CNC and retrofitting it if the envelope is sufficient for you.... |
