Old 12-28-2005, 03:28 PM
109jb is on a distinguished road
Help the newbie convert a mill/drill
I have a HF benchtop mill/drill I got several years ago that I have been wanting to convert to CNC for a while. I'm not sure the HF model number, but the specs are the same as the Grizzly G3358 http://www.grizzly.com/products/item...emnumber=G3358
I only plan on a 2-axis conversion at this point and have some stuff that I am wondering if they are sufficient for the conversion. First, I have 2 Superior Slo-Syn steppers one has a 300 oz-in hold and the other has a 450 oz-in hold. I also have a Stepperworld FET-4 controller board.
I plan to convert this one at as low a cost as possible. I will be installing rolled ballscrews on the X and Y though. My plan is to ultimately use this one to make parts for a larger square column mill drill. This one will then be retired and sold, or given to my father. I would really like to be able to use what I have right now.
So here are my questions.
Are these steppers appropriately sized for a 1:1 drive?
Would I be better off with a 2:1 drive?
I'd like to stick to a 1:1 drive for simplicity, but if it ain't gonna work then I can do the 2:1 or even more.
Also Can the FET-4 drive these steppers, or do I need to look for other controllers?
Thanks in advance,
John B
Old 12-28-2005, 04:27 PM
yukonho is on a distinguished road
I am guessing (it is a guess) that you would be OK with 2 450 oz steppers. I think the 300 would be too weak.
Gearing steppers down can actually give you less torque. The faster the stepper has to spin, the less torque it creates. Torque curves for your stepper will shed some light here.
I have no experience with the fet4, so can not comment there. If you are planning on staying with steppers, I would recommend getting Gecko's.
Colin
Old 12-29-2005, 03:53 AM
austin.mn is on a distinguished road
i just started my mill-drill conversion today, and i am using some nema 23 vextas, i originally thought that there was now way that they would do the job. i think they are like 150 oz motors. any who, the x axis was no problem, of course it has thrust bearings on it. the y axis was what concerned me. there is no bearings from the factory on it. mine is a speedway series, but i doubt there is much of a difference between that and the others. so what i did was removed the bearing carrier, y axis screw mount or what ever you want to call it, and i clearanced it out so i could add a thrust bearing. i am always on a tight budget so i usually look around my junk piles to find pieces and parts. the bearing came from a c-band satelite actuator gearbox. i then add another to the other side of the y mount. it was a huge difference from stock. the y axis feels as silky smoothe as the x. although i would love to convert it to ball screws, i am afraid it will not be in the budget for a while. but the way the machine feels now, i am not to worried about it.
i am hoping that tomorrow i will be able to finish the conversion, minus the limit switches, coolant and other accessories.
Old 02-24-2006, 08:29 AM
harty is on a distinguished road
Hi 109jb
i have a similar machine converted it to cnc about 3 years ago im running 200 in-oz stepper and 1:1ratio they work fine haven't lost any steps yet on a job the z has a 2:1 ratio off the stepper and will drill at an inch a minute with a 3/4" drill in mild steel thats better than i can do by hand
i have actually just started to convert to ball screws the 3 thou backlash just suckes hope this helps
cheers
peter
Old 02-24-2006, 10:01 PM
PeteZ28 is on a distinguished road
Originally Posted by harty
Hi 109jb
cheers
peter
What kind of feedrates under light/medium chiploads are you getting with this setup?
If 200oz/in steppers are working on that mill at 1:1 without loosing steps with leadscrews, I'm thinking the 300-400oz/in DC servo's with ballscrews I'm planning should absolutely fly on a machine similar in size to the original posters.
Thanks!
Old 02-25-2006, 09:08 AM
hi PeteZ28
i was cutting aluminium last night with a 5/8" end mill full cutter width at a depth of .1" and 30 inches a minute spindle speed 2500rpm
it actually started to stall the spindle but not the motors
stepper are 1:1 onto a 10tpi lead screw just plane old square thread
i have smashed a few 1/4" endmills off trying to feed to hard
im looking forward to getting the ballscrews on to get rid of the backlash should be sweeeeet
i think you will have a good machine with that setup
cheers
harty
Old 02-25-2006, 10:38 AM
Harty, thank you so much for the reply. I've been trying to get an idea of what size servo's I should use and asking questions on a bunch of forums. All I keep getting is the "depends on the application etc etc" and all I keep asking is what have OTHER people used and what was their results. Seemed like a pretty simple question and I thank you for finally answering it
Pete
Edit: Oh, what machine are you using that on? I'd love to see a few pics of your setup, thanks!
Old 02-25-2006, 08:54 PM
hi pete
my machine is in bits at the moment for the ballscrew conversion i will post some pic's of the conversion and the mill when its finnished
that should be in a couple of days
cheers
harty
Old 02-28-2006, 08:32 AM
here are the pics fo my ballscrew converson hope this helps
ID:	15086   Click image for larger version
ID:	15087   Click image for larger version
ID:	15088   Click image for larger version
ID:	15090   Click image for larger version
Old 02-28-2006, 08:33 AM
some more
ID:	15092   Click image for larger version
ID:	15093   Click image for larger version
ID:	15094   Click image for larger version
ID:	15096   Click image for larger version
  #11   Ban this user!
Old 02-28-2006, 08:35 AM
this is the last of them and it sure is nice to get rid of that backlash
cheers
harty
ID:	15098   Click image for larger version
ID:	15099   Click image for larger version
ID:	15100   Click image for larger version
  #12   Ban this user!
Old 02-28-2006, 10:22 AM
Harty,
That's a pretty nice looking ball screw conversion. I still haven't done my conversion yet because I just moved and am still getting settled. It sounds like my steppers will work, but I have a few other questions.
Here are the ballscrew questions
1. What size ballscrew are you using?
2. Are you using just the stock bearings for the leadscrews, or did you add anything (ie: needle, thrust, etc..)?
3. Are both ballnuts threaded into the aluminum blocks, or is one threaded and the other spring loaded to take backlash?
4. I see in one picture, the ballscrew comes through the belt sprocket, but others look like you are using an adapter with set-screws. Can you elaborate on how you are taking care of thrust and power transmission?
Other Questions
1. What stepper controller are you using?
John B.
AKA 109JB
