Results 1 to 5 of 5
Thread: Stepper motor help
    Jun 2012
    canada
    Stepper motor help
    Can someone help me out here I'm new to this cnc conversion
    I can only get 22 ipm with my steeper's before the buzz and stop
    I have tried everything I can to get them to go faster with no luck
    My spec's are
    Motor
    Nema 23 400oz model 23HS2430 3A
    1.8 step angle
    3 amp
    1.6 phase resistance
    6.8 phase induct
    4 wire
    Driver
    DM542
    128 microstep
    1 amp to 4.2 amp
    18 to 50 VDC
    Power suppy
    350 watt 24 VDC
    Everything is from act-motor
    My lead screw is 10 tpi
    Everytime I try cutting any curve it studders I have CV turned on and
    all the other setting for it turns off I am using mach3
    What should my settings be in motor tuning in mach3 ?
    Thanks for the help and this is a awesome forum for info
    Glad I found it.
    Hurricane-fibers
    Jan 2005
    What kind of machine? Ball screws, acme screws, or other?
    Based on an inductance of 6.8, you should be at about 80V for your power supply (sqrt(6.8)*32). So, you are basically getting 1/3 of your motors potential power.
    Jun 2012
    canada
    I have acme screw
    So I'm out of luck to get any more then 25 ipm ?
    I'm new to building my own cnc
    But will the volts make that much difference in my speed ?
    Jan 2005
    The acme screw is a lot more drag than ballscrews, and the voltage is just about directly proportional to speed. So, 1/3 the voltage and you are at 1/3 the speed. Factor in the acme screw and you could potentially get a whole lot more speed if you had the correct voltage and ballscrews
    Jun 2012
    canada
    Ok thanks for the info
    I will get a bigger power supply
    I have 2 24 volt one's is there a way to use both to get 48 volts ?
    I was thinking the same way as a 2 battery to double the volts will this work lol
    Just a shot in the dark here
    Hurricane
    1. Replies: 0
      Last Post: 01-22-2012, 03:30 AM
    2. Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
      By guy2b1 in forum DIY CNC Router Table Machines
      Last Post: 03-08-2011, 06:50 AM
    3. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
      By wf1318 in forum Stepper Motors and Drives
      Last Post: 07-25-2010, 03:19 AM
    4. Integrated stepper motor? with built-in stepper motor driver
      By uirobot in forum Product and Manufacturer Announcements
      Last Post: 06-07-2010, 04:59 AM
    5. Beltdrive-stepper motor-stepper motor driver
      By Georg in forum Stepper Motors and Drives
      Last Post: 10-16-2007, 05:56 PM
