Results 1 to 2 of 2
Thread: Will the KBLC-19M work with a PMDX-106?
    Sep 2005
    Anyone ever try this? Since the PMDX-106 is a PWM type board can it drive the KBLC as a speed controller?
    If so how did you set it up?
    I'm using Mach3.
    I've skimmed through the PMDX-106 Application Notes but not sure they will work together.
    Thanks in advance,
    Vogavt
    Apr 2004
    VA, USA
    Yes, the PMDX-106 can control a KBLC motor driver.
    The PMDX-106 does the analog control by simulating
    the speed pot normally connected to the KBLC. The
    PWM signal will control the analog voltage and will
    also turn on and off a small relay on the PMDX-106
    for commanding Forward run. We do not recommend
    using the Inhibit function on the KBLC or KBIC drivers
    as a way to stop the motor because it is not failsafe
    when wiring breaks. We recommend using the small
    Forward relay on the PMDX-106 to control a larger
    relay the removes the AC mains power from the KBLC
    when the motor should stop. The basic KBLC cannot
    reverse the motor, so no direction signal is needed.
    The PMDX-106 has an on board inverter to provide
    the isolated power needed to safely interface with
    drivers like the KBLC whose interface signals ride
    at AC mains voltage potential.
    Regards,
    Steve Stallings
    www.PMDX.com
  1. Build Thread- Will the KBLC-19M work with brushless motors?
    By Vogavt in forum Benchtop Machines
    Last Post: 06-09-2012, 03:50 PM
  2. KBLC-240 (KBIC) and voltage following--how?
    By vputz in forum Controller & Computer Solutions
    Last Post: 05-15-2012, 07:56 PM
  3. Need Help!- PMDX 107 to Huanyang - refusing to work
    By jestah in forum DIY CNC Router Table Machines
    Last Post: 02-06-2011, 09:24 PM
  4. Need Help!- KBLC-19PM Control Board Help! UPDATE
    By dkolean in forum Benchtop Machines
    Last Post: 11-26-2010, 10:59 PM
  5. PMDX-125 or PMDX-132 for Geckos?
    By Nivea in forum Gecko Drives
    Last Post: 03-24-2010, 03:18 AM
