Results 1 to 7 of 7
Thread: need a new stepper
    Sep 2011
    america
    need a new stepper
    I originally bought my steppers for a home made machine. they worked great on that machine but the construction job I did On the machine didn't work well. So I bought the X2 mill from harbor freight and a conversion kit. The stepper just isn't strong enough to lift that 35 pound head. I took the stepper off and it worked great. I put it back on same problem. So With my free arm I gave it a helping hand and it went up great every time. So how strong of nema 23 stepper do I need to lift that head. I thought of a counter weight system but the X wife got most of the tools in the divorce except the mill so I have nothing left to build one with. I would rather just buy a stronger stepper motor. these by the way are KL23H284-35-4BR (1/4” Dual shaft with a flat) 355 oz-in would a NEMA 23 Stepper Motor: KL23H2100-30-4BM (1/4” Dual shaft with a flat) 495 oz-in work. The main thing I will be cutting is aluminum and synthetic rifle stocks. Or will I need stronger then that say something like a 570 oz-in? witch I don't want to go up to because of cost and I would have to get a new lovejoy coupler.
    Gold Member hoss2006's Avatar
    Apr 2006
    Depends, what driver are you running and what voltage?
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Sep 2011
    america
    the power pack is the KL-600-48 48V/12.5A and the drivers are the KL-6050 the z axis is set for 5.0 amp and half step. Sorry should have given that info in the OP. I like buying from keling inc there prices seem fair and there shipping and packing are fast and great.
    Apr 2006
    Well you're putting too much current to the 355, it's a 3.5 amp motor.
    Try setting the 6050 to 3.5amps.
    The 355 would also like to run at 65 volts for best performance so 48 is under powering it.
    The 355 should manage the x2 z unless you have gib binding.
    the 570 stepper is a great match for the 6050 @ 48 volts and would have no trouble with the z
    if you want to upgrade the motor, it's more than what's necessary but it'll certainly do the job.
    Hoss
    Sep 2011
    america
    Well that sucks I emailed them and asked for advise and told them the drivers and steppers I had and they were the ones who told me to get that power supply. So will it do the job if I can find the bind?
    Feb 2006
    Running a 3.5A stepper at 5A, you've likely de-magnetized the motor, greatly reducing its torque output. Steppers should NEVER be run above their rated current, and should NEVER be take apart. Doing either can easily reduce torque by 30-50%.
    Regards,
    Ray L.
    Apr 2006
    If running the 355 at 5 amps hasn't cooked it already.
    I'd get a 381 or 570 first rather than getting a bigger power supply, they run great at 48 volts.
    Yeah, make sure the head moves easily too.
    Hoss
    1. Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
      By guy2b1 in forum DIY CNC Router Table Machines
      Last Post: 03-08-2011, 06:50 AM
    2. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
      By wf1318 in forum Stepper Motors and Drives
      Last Post: 07-25-2010, 03:19 AM
    3. Integrated stepper motor? with built-in stepper motor driver
      By uirobot in forum Product and Manufacturer Announcements
      Last Post: 06-07-2010, 04:59 AM
    4. Wanted DIY stepper driver circuit for 6 wire stepper motors
      By Colin300 in forum Australia, New Zealand Club house
      Last Post: 09-20-2007, 10:20 PM
    5. difference between a stepper indexer and a stepper drive
      By pcroxford in forum Stepper Motors and Drives
      Last Post: 11-02-2005, 08:35 AM
