Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Best Benchtop Milling Machine
    May 2012
    Puerto Rico
    I just want to ask in your personal experiences which benchtop milling machine is the best? I have been looking differents machine but they all seem the same.
    Grizzly G0704, *Lathemaster LMT25L, Seig x3 milling machine, etc.
    How can I know the difference between these machines and which one is the best for the price?
    Aug 2008
    I can only speak to the G0704, but I am very satisfied with the product and Grizzly's support, I would imagine that they all are very similar in their production for this range machine, I made my choice based on price and was lucky to have Grizzly deliver within 4 days of placing my order, others have had long wait times so this may be a big determining factor if the mills are not available for immediate shipment.
    Chris
    Aug 2010
    So far very happy with my G0704 as well... i think for the money you have a hard time to beat it. I also was very lucky and got it delivered 4days after placing my order.
    [URL="http://www.hive8.com"]Hive 8[/URL] - [I]G0704 CNC Mill - 20 inch Telescope - High Resolution 3D Printer - Lasersaur 100W CO2 Cutter / Engraver[/I]
    Gold Member hoss2006's Avatar
    Apr 2006
    Best at what?
    What's best for your needs may not be best for mine.
    However, I made a chart a while back comparing 5 popular machines and their most prominent advertised specs.
    Many other machines could be added with many more specs though.
    Hoss
    Attached Thumbnails Attached Thumbnails Best Benchtop Milling Machine-g0704_ranking.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Registered FannBlade's Avatar
    Jun 2011
    Quote Originally Posted by hoss2006 View Post
    Best at what?
    Hoss
    any thoughts on this one? Vertical-Mill/G0678
    Jan 2005
    Quote Originally Posted by FannBlade View Post
    That looks like an OK machine, but since it is a knee mill, I personally would go for a used bridgeport or other quality brand machine. A decent one coul be had for about 1/2 the price of that Grizzly mill.
    Some of the pros and cons I see with that mill compared to a bridgeport are:
    Pro - VFD controlled motor
    Con - Smaller table than a bridgeport
    Con - Ram does not extend like a bridgeport does
    Con - It doesn't appear that the head tilt has a worm drive to assist in tilting/raising the head and tramming.
    You expressed an interest in CNC, and having worked as a machinist on manual and CNC mills, I have the following observations. A knee mill can definitely be made into a CNC machine and I have worked on several that were. One that I worked with was X and Y axis only with manual positioning of the Z. Several were X,Y, Z with the Z axis being movement of the quill. One that I worked on had a goofy setup with X,Y,Z1,Z2 where Z1 was quill, and Z2 was the knee.
    The X-Y only would be easy to do, but it is a bit of a pain to work with just X-Y.
    The XYZ with quill feed works very well, but you are limited in Z travel a bit. On those machines I found myself haveing to raise and lower the knee sometimes to change tools, or get clearance, or similar. Worked pretty well though and since raising the knee is accurate and you don't lose XY position it wasn't that bad.
    The machine that had X-Y-Z1-Z2 worked reallly well, but we never used Z1. All the guys that used that machine quickly found out that it was much easier to just program all of the Z moves into moving the knee. It worked really well.
    The thing you have to consider strongly on converting a knee mill is what system you will need (servo or stepper), and what that means to cost and setting it up. They can be converted and make very nice capable CNC machines. Depends on what you want out of it.
    Having said that, consider that a true VMC does not have a knee. They work by having a bunch of head travel. This is exactly how a square column mill drill works. Sure they have a quill too, but when CNC'd the quill is generally not used, so esentially you are mimicking the way a VMC works. They also work pretty darn well for a manual mill to if that is how you want to start out. The square column mill drills come in a variety of sizes from table top model that one guy can carry easily up to almost 1000 pound monsters. All of the mill in this range have been converted to CNC at one time or another.
    If I were going to buy a mill right now for my own personal use, with the experiences I have had, I would buy a square column mill drill. Depending on what you want to do with it would determine the size you would go for.
    It sounds like you may not have much machining experience, so might I suggest that you try the lower end of the scale instead of sinking $10K into something you may not need. You can get a mini square column mill like this one:
    G8689 Mini Milling Machine
    Then CNC it and have a whole lot less money into it than buying something that may be great but overkill for what you actually want to do. These can be made into pretty good little CNC hobby mills as has been shown many times by many people. Are they suited to mass production of large parts? no, but they can get you a lot of experience with machining and CNC.
    Just like you don't need a sledgehammer to drive a finish nail, you don't need a CNC mill with a huge table if you want to make small parts.
    My opinion (Worth what you paid for it)
    Jun 2011
    Good point on the travel.
    Also looking at this one G0720R
    The one you listed is way to small. I'm converting a 3n1 now and looks like i'm going to dump the mill head and just use the lathe so need a suitable replacement.
    The large part I need it for is 24x9x1 6061 with about 70% material removal.
    Spent all day yesterday on the Tormach site and also think the 770 will suit me needs very well and is designed to be disassemble to move were the 1100 isn't. But will also cost 5 times the grizzly and I still need budget for the CRP4848 that I will use to do the finish cuts.
    Converting doesn't bother me but sure is hard without a mill to cut parts.
    My CNC build: http://www.cnczone.com/forums/genera...ml#post1059321
    C-Constant
    N-Nonworking
    C-Contraption
    Jan 2005
    OK. Knowing the size of the biggest part you want to do helps. That size part, if you want to do it all in one setup will need a pretty large machine. You are looking at the RF-45 size machine, but not all of them are created equal. The table size and travels differ from machine to machine. The G0720R lists table travel of 9-5/8 x 16-1/8 on the table. Not enough for the 24 x 9" size of your part. You can usually get a little more travel than the specs say by modifying slightly, but I don't think you will get 8" more on X on that one. You could fixture to do the part in 2 stages, or get a bigger machine. International hobbies sells a much improved dovetail mill that has 12" x 30" table travel. Not sure about price as they no longer have an online store, but they also offer a CNC version of their mill that uses closed loop feedback servo control. Might be an option. Here is their link.
    IH CNC Mills & Machinery - Made in the USA
    Another RF-45 clone that I have been looking at because of price is the Penn Tools top tech mill. At $1695 (May 2012) it is about the lowest cost RF-45 I have seen. It has 20 x 9 travel and by modifying and using a little overtravel I think you may be able to get the 24+ inch X travel you are looking for. You would also need to get a little more Y travel, but its already at 9" so shouldn't take much. I was able to get about an extra 1-1/2 inches on my little RF-25 clone. It may take a little doing though, so don't take that part to the bank so to speak. Here is a link. Top Tech Geared Head Mill/Drill Dovetail Column - Swivel Head 90° << Metal Working Machinery << Online Catalog << Penn Tool Co.
    For the size part you are looking at, a used 9x49 Bridgeport would have the table travel you need. This might not be a bad option. If the part is only 1" thick, a Z axis quill could probably do what you want with manual positioning of the knee if necessary. A power feed on the knee makes this part not too bad of a compromise. If you decide to CNC the knee for the Z axis, I think a servo would be best unless you are willing to live with some slower Z-axis feed rates.
    CNC knee mills are also easy to find on the used market. Might want to consider this route. Here is one ebay right now. Used machinery dealers will also have CNC knee mills.
    Tree Journeyman 320 3-Axis 2HP CNC Milling Machine | eBay
    Not knowing all of the particulars of your part (how many, how often, tolerances, etc.), it is hard to say, but doing the part in 2 separate setups may be a good compromise too.
    One thing to consider with a part that large is holding tolerances. The motors and control software have good precision but the mechanics of the machine come into play. At the lengths you are talking about, you would be best with ground zero-backlash ballscrews $$$$ and then would still need to map the screws. If your tolerances are at all tight, you may just be best off with a real CNC machine with box ways, proven track record, etc. The Tormach may be a good choice in that regard.
    Registered Mad Welder's Avatar
    Jun 2011
    Ireland
    Quote Originally Posted by Engineer123 View Post
    Hi there Engineer123, welcome.... and it really boils down to what do you require your machine to do, and if you can be more specific as to your future machining requirements...well then someone here would be more specific in their recomendations for you too, otherwise you'll get multiple machine suggestions and each suggestion in it's self would be valid for each of us who suggested it because it suited our needs......
    hope this hasn't confused you more either, but that chart Hoss suggested in post 4 below, I also looked at it before I made my decision......
    Eoin
    Feb 2009
    Went through this with my father recently. Found a lot of these mills didn't have tapered gibs, a nice feature to have. He placed an order from grizzly for the $3800 dollar one, they kept sending him emails saying its a new machine, shipment delayed for months. He then found a pm full size knee mill on eBay brand new. It was slightly shorter table than a Bridgeport, didn't have the Bridgeport mounting eye on the back of the ram so it fit better in the garage. Came with single phase vfd, DROs,a vice and collets and I think a clamp set. Was about 4200 delivered. Look around.
    Jun 2011
    Defiantly going to look around. I would really like to just find the iron and build from there. I have a wholesale tool down the street think I will go see if they have a junk pile.
    Saw some good prices on VMC's today on ebay in the $6000-$8000 range.
    I hate to buy a new machine then replace everything with more new parts.
    Sorry about hijacking this thread hope the OP doesn't mind.
    C-Constant
    N-Nonworking
    C-Contraption
    Oct 2011
    Mill choices
    You may want to look at the Machine Tools Warehouse MD001. It is a clone of the IH mill. Square column, 12" X 30" travel (Y,X) and a good 20" plus of Z travel. It's heavy, nearly 1000 lbs and has a slightly wider spindle speed range.
    On the down side, expect to do some tweaking to get things straight and square over the entire range.
  • Page 1 of 2 12 LastLast
    1. Newbie- Roland MDX-540 Benchtop milling machine
      By inventor1227 in forum Benchtop Machines
      Last Post: 05-20-2013, 11:41 AM
    2. open source cast iron box way benchtop milling machine
      By ihavenofish in forum Benchtop Machines
      Last Post: 05-20-2013, 05:13 AM
    3. 3 axis benchtop cnc machine
      By CNCadmin in forum EBAY ADS
      Last Post: 03-24-2011, 07:40 AM
    4. Benchtop machine sale
      By DareBee in forum Canadian Club House
      Last Post: 09-16-2008, 11:49 AM
    5. Which Benchtop machine do you own.
      By wisp in forum Polls
      Last Post: 02-24-2007, 04:34 PM
