Results 1 to 6 of 6
Thread: loosing steps in z axis
    Jan 2011
    I have been loosing step in my z to the point of a crash that put a end mill into my table!It happens most on retract moves as it starts up I hear that grinding sound.After a second it kicks back in but does not reach its retract height.So when it goes back down for the next cut it adds the distance it lost on retract to the plunge.It sucks to run a part and keep 1 hand on the E STOP!I am new to this cnc game as this is my first conversion I dont know much about all the tech stuff with steppers and drive ect.I don't really want to know that much I just want my mill to work.I have a nema 34 906 in/oz kelig motor,a 8060 drive running at half step mode.My Mach3 settings are steps per 2400 velocity 38.124 accell 4.375 this is on a G704 with stock screws with 10TPI.I dont know if I have this set right.I want to thank Hoss for helping with some tips to this point.Any Ideas please let me know.My table thanks you!
    Jan 2005
    What voltage are you running to your motor?
    What amperage do you have going to it?
    That is an 8-wire motor. Do you have it wires in series or parallel?
    In parallel you should be at about 50 volts and 6 amps
    In series you should be about 115 V and 3 amps.
    If you are running a 10 TPI lead screw with the drivers set for 1/2 step then you should be 2000 steps per inch in your controller software.
    Are your gibs too tight?
    Lots of things to consider.
    Gold Member hoss2006's Avatar
    Apr 2006
    Is the z motor an 8 wire and if so are you sure it's connected bipolar parallel?
    The stock screw is 6 tpi but your 2400 steps/per is correct for direct drive, are
    you running a belt reduction?
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jan 2011
    missed steps
    I HAVE 48V AT 6 AMPS ON A 4 WIRE MOTOR WIRED BIPOLAR PARALLEL.MY BAD ON THE 10TPI IT IS 6 AS HOSS POINTED OUT.IT ONLY DOES IT PART TIME THE REST OF THE TIME IT SOUNDS AND RUNS GREAT AS FAR AS I CAN TELL.
    Registered Connor9220's Avatar
    Aug 2010
    Quote Originally Posted by macatoms
    It's possible that the jam nuts on the Z axis are too tight. Its also possible your shaft adapter tightens the jam nuts and loosens them causing issues. I didn't have my jam nuts tight enough and it unscrewed them causing the head to drop Anyway, What is the top IPM you can do with the Z? I'm running stock screws with a 570oz-in and can push 70IPM but have limited it to 50IPM. If you are not able to get those speeds then check that and maybe check to gibs to see if you have the to tight.
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
    Aug 2010
    Quote Originally Posted by Connor9220
    Oh yea. SLOW acceleration helped allot.
    1. Need Help!- Axis loosing steps
      By Vogavt in forum Benchtop Machines
      Last Post: 01-07-2010, 12:01 PM
    2. Y Axis Bind and Loosing Steps
      By ranchak in forum Bridgeport and Hardinge Mills
      Last Post: 11-04-2009, 07:09 PM
    3. Taig CNC loosing steps again
      By diamondback21 in forum Taig Mills & Lathes
      Last Post: 05-25-2009, 02:21 AM
    4. Need Help!- BP series 1 loosing steps
      By bartL in forum Bridgeport and Hardinge Mills
      Last Post: 07-16-2008, 01:55 PM
    5. Loosing steps
      By Normann in forum Automation Technology Products
      Last Post: 10-15-2007, 03:15 AM
