Here are a few pics of the mill.
The first pic is a general view of the mill. You can see the X & Z stepper motors and the swing arm mount for the flat panel monitor. Y axis stepper is mounted onthe back of the machine.
The second pic shows the familiar stand - boxes on top contain the PC & monitor.
Pic 3 is a close up of the truly massive Z axis stepper.
Pic 4 is a shot of the inside of the stand showing the PS & stepper motor controllers installed in the upper section. It's not real clear - will get a better one later on. The Pwr. cable, parallel port connector, stepper motor connectors and switched outlet for the coolant pump are on the right side of the stand. A cooling fan is on the left side.
LinkBack URL
About LinkBacks
