Hi everyone,
This is my first post. We are building a CNC Lathe where I work, pretty much from scratch.
We have a MagMotors DC motor from another machine we want to use as the spindle.
I'm now looking for a DC motor driver that will allow us to control this motor using an Arduino.
From what I have seen the best option we have is to use a KB Electronics KBWS-25D.
This would allow us to power it straight from the wall socket (we are in europe, so 220VAC), setting the KBWS-25D to 90-120VDC output to the MagMotor that is rated for 130VDC and be controlled by the arduino from the 0-5VDC speed control input using.
The motor is rated at 7.5A and the speed controller only for 5A. This is the only problem I can see but I don't know if that means we will not be able to reach max RPM or if it won't work at all.
Thank you in advance for your help,
LinkBack URL
About LinkBacks
