Page 1 of 8 1234 ... LastLast
Results 1 to 12 of 92
Thread: Hive8 G0704 CNC Build
    Aug 2010
    Hello everyone together... I wanted to document my build here, i ordered the mill from Grizzly on April 23rd and got it delivered today, Box everything seems fine and i will put it in the shop to look it over... Ordering and delivery was really smooth and fast. I will post pictures later...
    Now its time to take it appart, clean everything and start the conversation...
    What i wanted to do is the following...
    Now:
    CNC build with Keiling Digital Drivers based on Hoss Heavy Digital Kit...
    Threatmill Motor Conversation with Belt
    Later:
    New Mounts for the Stepper Motors
    New Screws to get the blacklash out...
    Oiler
    Mist Cooler or Fluid Cooling
    Enclosure
    Attached Thumbnails Attached Thumbnails Hive8 G0704 CNC Build-photo_apr_27_18_36_27.jpg   Hive8 G0704 CNC Build-photo_apr_27_18_37_13.jpg
    [URL="http://www.hive8.com"]Hive 8[/URL] - [I]G0704 CNC Mill - 20 inch Telescope - High Resolution 3D Printer - Lasersaur 100W CO2 Cutter / Engraver[/I]
    Gold Member hoss2006's Avatar
    Apr 2006
    Welcome to the club hive! Man, sounds like you ordered at the perfect time.
    Make sure to read thru the manual, there is good basic info in there on setting up the mill
    that many seem to overlook.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Oct 2009
    And let us know if the 3 bolt mod is already done or not
    Registered Mad Welder's Avatar
    Jun 2011
    Ireland
    Quote Originally Posted by hive8 View Post
    ... I wanted to document my build here.......What i wanted to do is the following...
    Now:
    Later:
    Oiler
    Enclosure
    Hi there hive8 welcome, you're off to a good start since you're prioritising….. And like you’re going to do I used my conversion to make better mounts too….
    Keep loads of pics flowing too….
    Eoin
    Aug 2010
    Will be taking the mill apart on the weekend, its still in the box, kkk...
    Just wanted to update and show what i am going to make with it mainly, some laser modules i have been planning for some time now.
    Btw the dimensions are mm, kkk
    Attached Thumbnails Attached Thumbnails Hive8 G0704 CNC Build-laser_q_closed.jpg   Hive8 G0704 CNC Build-quad_q_open.jpg   Hive8 G0704 CNC Build-xy_mirror_mount.jpg
    Registered fatal-exception's Avatar
    Mar 2006
    Nice design and renderings. What are the lasers for?
    Your planning steppers rather than servos?
    Paul
    Aug 2010
    These lasers are modules that i use for shows i do here in Los Angeles... But why not sell them later if people like them . I am going to Stepper route with the Digital Keiling Drivers 5060D right now containplating about the Computer and Software Setup...
    Option 1:
    Mach 3 ($149) with a Ethernet Smooth Stepper ($189)
    Option 2:
    LinuxCNC (former EMC2 + (free)) with a parallel port
    i have a amd PC i can use for that if not i would need to get one of these ATOM CPU boards that everyone is using.
    Since i want to do HSM path not sure if the parallel port can handle it, i have been reading it generates a lot of GCode...
    But i will know and see in the next 1 - 2 weeks...
    Jun 2011
    Ireland
    Yeah the Smooth Stepper (and I see you're quoting the Eithernet version price) will rid the host PC of the processing and should definitely help you towards your HSM....and I love the renderings, what CAD rendering are you using?
    Eoin
    Aug 2010
    I use Solidworks 2012, i have been using it since the year 2000 when i saw it first and fell in love, i did a project for this company Stark Mounting Systems (Welcome to STARK Spannsysteme GmbH)... changed there internal system for dealing with media (Catalogs, Graphics, Animations, 3D Catalogs, Website and so on), but then i moved to Los Angeles... kkk.
    Rendering was also done in Solidworks, but i will give this new program a try called Keyshot 3 (KeyShot - 3D Rendering and Animation software) and for CAD i heard a lot of good things about SpaceClaim (SpaceClaim|3D Direct Modeling Software for Engineering, Manufacturing and CAE), i wanted to try that as well... its insane how fast it is and what you can do with it...
    Apr 2006
    Thanks for the links, might just have to try them to pretty up my models.
    Hoss
    Aug 2010
    Hoss if you need any help with models, CAD, Rendering or WEB let me know i am more then welcome to help you out... just a way of giving back since you help a lot in my reseach for the mill and the CNC part...
    Jun 2011
    Ireland
    I use Solidworks 2012....but i will give this new program a try called Keyshot 3...
    Yeah cheers for the links and Keyshot is also offered with Alibre as a plugin option for rendering too it's a pretty darn good piece of software as when I was researching my CAD/CAM software I looked into Alibre....but now I use Rhino (well I'm still learning) and I bought it for it's 3D free form surface modelling capabilities it’s flippin brilliant….as I couldn’t download an evaluation version of Solidworks, does it have the ability to create surfacing drawings?
    Eoin
  • Page 1 of 8 1234 ... LastLast
    1. Anyone build a servo G0704 yet?
      By bogiestl in forum Benchtop Machines
      Last Post: 03-28-2012, 11:53 PM
    2. New Machine Build- Mwood's G0704 Build
      By mwood3 in forum Benchtop Machines
      Last Post: 09-06-2011, 06:40 PM
    3. G0704 - CoB's Build
      By cobmachine in forum Benchtop Machines
      Last Post: 06-20-2011, 03:34 PM
    4. need wisdom on g0704 build
      By macatoms in forum Benchtop Machines
      Last Post: 02-13-2011, 10:20 PM
    5. Build Thread- Grizzly G0704 Build
      By nocashvalue in forum Benchtop Machines
      Last Post: 11-15-2010, 10:33 PM
