Mine could definitely hold 0.005" without any mods, but fixing the gibs should only take half an hour with some wet dry sandpaper and a flat surface.
Most of these problems have an impact of less than 2 thou so you will be fine unless you go to the very ends of the table.
If you are flipping a part to machine both sides things may get harder though since most of the issues affect the Z so the error will get doubled.
LinkBack URL
About LinkBacks
