Page 5 of 6 FirstFirst ... 23456 LastLast
Results 49 to 60 of 71
Thread: Wiring digital driver to BOB?
  1. #49
    Sep 2011
    Well, I got a new BOB, and new problems. This is the one I picked up:
    http://www.tecnoflexo.com.br/site/fo...load/17/17.pdf
    Now, in trying to wire it up I discovered that the little 4-screw terminal blocks were defaulted as 5V power supplies with the one the end being the ground until they were assigned Step and Dir pins in Mach 3. This doenst work, of course. With the machine configured in the way the manual illustrates the motor turns in one direction (sounds familiar). With an external USB cable providing my 5V it works fine. On the volt meter I get 5.08V from the BOB screw terminal and 5.18V from the UBS cable coming from my computer. Ive tried switching them around and nothing works.
    Not only that, but when you assign a pin to step or dir, it stops being a 5V power supply...permanently. They now read zip on the volt-meter and I cant get the unassigned pins to go back to being 5V+.
    The BOB is supposed to be supplied by USB, but it looks like I need a SECOND USB cable to power the 5V going to the drivers.
    Any advice? This is white-knuckle frustrating. It seems like a miracle that people just buy their parts and build machines like this without the avalanche of problems im having. Where do you all learn how to do this? I consider myself to be pretty good at technical stuff but never before have seen anything like this- Example: The new BOB came with a manual that suggested a setup in mach 3 that didnt work. The wiring diagram I got with my drivers and steppers didnt work. How is this the way things are done? Its as if vendors expect you to just know what to do despite giving terrible advice.
  2. #50
    Jan 2005
    Look at the attached picture.
    Then in Mach you need to assign the following in the configuration menus (see pictures). Make note of the green check marks. This is how it should look for a 3 axis machine.
    Under the "Motor Outputs" tab
    X axis dir pin - 2
    X axis Step pin - 14
    Y axis dir pin - 16
    Y axis Step pin - 3
    Z axis dir pin - 7
    Z axis Step pin - 8
    Under the "Output Signals" tab
    Enable 1 - pin 1
    Enable 2 - pin 1
    Enable 3 - pin 1
    Attached Thumbnails Attached Thumbnails Wiring digital driver to BOB?-hookup.jpg   Wiring digital driver to BOB?-motors.jpg   Wiring digital driver to BOB?-outputs.jpg
  3. #51
    Sep 2011
    AH! Thank you 109jb
    Its working...sort of.
    I ordered a Keling KL5056 to replace my fried DQM5042MA driver. I wanted a Keling because everyone raves about them and I didnt want to worry about replacing another driver....So of course its broken.
    Yep. The Keling is the driver that is malfunctioning apparently. I have it set up just like the others and it only turns one direction and VERY slowly. I have connected it to the other motors and different pin sets on the BOB and it has the same effect on any motor it is controlling. Damn.
    I have it set up at 10 microsteps and 4.3A (to get close to the 4.2 of the other drivers). Setting it to half current when idle has no effect.I called up John at Automation Technology (who I bought it from) and he said to just send it back for a new one.
    Is there anything I could be doing wrong? It just seems like the odds are against this happening.
  4. #52
    Sep 2011
    Well, its not working any more. Or more accurately, it works in spurts or not at all. I returned my Keling 5056 for a new one (replacing the one that blew, which was itself a replacement for another that blew). So ive had to replace 2 of 3 drivers so far. Something is terribly wrong here and I cant figure out what it is.
    Right now, only one axis will work. This is weird because when I was troubleshooting the bad driver, all 3 were working somewhat. None work all the time. If I turn off the machine and power it back on, random axis will work or not, or go in only one direction. The new keling driver doesnt move anything at all, fresh out of the box. I dont even know where to start.
    And yes, Ive checked my wiring over and over
    Any suggestions anyone?
  • #53
    Oct 2005
    Quote Originally Posted by SwampDonkey View Post
    Do you have a green light on the driver?
    We sold so many digital drivers, if one of them is not working, it is possible.
    But it is impossible for all three bad drivers together. if you do not t know how to set up, pls contact us for support. we will help you
    High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Automation Technology Inc
  • #54
    Sep 2011
    Quote Originally Posted by Kelinginc View Post
    Yes, all three lights are on.
    Im using the RJ-45 adapters from CNC4PC to simplify the wiring, and that may be the problem. Ive bought new 18g wiring to replace the $30 worth of adapters and cables I bought...
    I was actually going to contact you in the morning. What number should I call?
    Thank you much!
  • #55
    Sep 2011
    I emailed customer support, followed the directions in the return email, NOTHING.
    Does anyone know how to wire this thing? I have the PUL- and DIR- set to the BOB output pins as per the wiring diagram, and the 5+ common to the rest. The ENA terminals are left unconnected. It still wont work!
    Ive tried everything, and if its malfunctioning then this is the second Keling driver in a row from Automation Technologies to fail. The leadshine drivers from China are running like a champ.
    Anyone have any advice?
  • #56
    Jan 2005
    are you running this on a laptop through a parallel port on the laptop by chance? If so, many laptop parallel ports don't output a strong enough signal.
  • #57
    Sep 2011
    Quote Originally Posted by 109jb View Post
    Nope. A desktop. And it runs the other drivers perfectly. So I have 2 axis working and the one driving the Keling just sits there with the green light on.
  • #58
    Jan 2005
    I just re-read this part. What you have indicated sounds wrong for the BOB you said you have.
    The PUL-, DIR-, and ENA- should all be hooked up to the GND terminal on the BOB. The PUL+ goes to the XS, YS, ZS.. as appropriate. The DIR+ goes to the XD, YD, ZD... as appropriate. The ENA+ goes to the XE, YE, ZE... as appropriate.
  • #59
    Sep 2011
    Ah, nice. I'll give that a shot. This is the diagram sent to me from AT:
    http://www.kelinginc.net/KL-5056WiringDB25.pdf
    Along with the directions to leave ENA terminals unconnected.
    Thanks! I will report back shortly
  • #60
    Jan 2005
    Both wiring options are valid depending on the BOB you use, but for the BOB you said you have it should be wired like this picture that is in the KL-5056D manual that you can download from the following link:
    http://www.automationtechnologiesinc...load.php?id=51
    Attached Thumbnails Attached Thumbnails Wiring digital driver to BOB?-wiring.jpg
  • Page 5 of 6 FirstFirst ... 23456 LastLast
    1. Digital Stepper Driver
      By kolias in forum Open Source CNC Machine Designs
      Last Post: 03-08-2012, 08:03 AM
    2. Can you pulse a digital driver manually?
      By Fastest1 in forum Stepper Motors and Drives
      Last Post: 08-18-2011, 01:35 AM
    3. digital stepper motor driver for X2 conversion
      By sabastion in forum X3/SX3/G0619/G0463
      Last Post: 08-03-2011, 09:23 AM
    4. Digital Stepper Motor Driver Exprience
      By Kelinginc in forum Automation Technology Products
      Last Post: 07-26-2011, 11:04 PM
    5. Digital tool dr902 wiring diagram
      By brockadeau in forum BobCad-Cam
      Last Post: 05-16-2007, 12:41 AM
