Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: HF round column mill drill build
    Jan 2005
    Decided to start a new thread to catalog the build of my round column HF mill. The mill is one that I bought in 1997 and is a model 981. It is about the size of a RF-25 or a Grizzly G1005. Just a bit smaller table. The table is 6.25" x 20.25". I really want an RF-45 size machine, but it isn't in the budget for a while, so even though this is a round column mill, I decided to go ahead and convert this one to get some experience in converting a machine to CNC. I figure I can use this experience when I can get a RF 45 type machine, and if I can get the RF45 machine before I have to sell this one I can use it to make the parts for the RF45 machine. The machine is in pretty good shape, but has seen some storage time during moves and has to live in my barn that I can't afford to keep heated all the time. Here is a picture of the machine before any conversion work was done.
    The first thing to do was to get a plan of attack and a decision on what motors to use. For this size machine, I decided that steppers was the way to go. I actually started thinking about this about 6 years ago and back then I bought a stepper kit from Stepper World to play with. I also have a 9"x20" grizzly lathe that I figured I could use the 150 oz-in steppers on. I started a thread a few weeks ago that shows my motor decision. With the help of some fine people on this forum, I have settled on the Keling 570 oz-in steppers and will eventually power them with some good drivers and a 50V power supply. Due to money constraints though I will start with the 570-oz-in motors and TB6560 single axis drives and a separate breakout board and a 24V switching power supply. Here are a couple pictures of the BOB and drivers that I plan to use initially.
    From the start I knew I wanted ballscrews and settled on the McMaster Carr rolled ball screws with spring loaded double ball nuts for zero backlash. So, this is the first task I tackled was making all of the ball screw mounts and designing the motor mounts for the steppers. The problem many have encountered when converting their machines is that you first have to take the machine apart, measure everything as accurately as possible, and re-assemble the machine so you can make the parts, and hope your measurements were close enough to have everything work right. I did all that, made the parts and now have a machine that has ballscrews installed.
    This first picture shows the y-axis ball screw assembly. You can see the bearing mount at the left , and the double ball nut and the mount that connects to the table saddle. One ball nut is screwed into the saddle bracket. I used blue locktite to hold that ball nut into the mount. rotation of the other ball nut is prevented by the bar across the bottom. The ball screw is welded to a machined end fitting that I made on my little lathe. I held the ball screw in my lathe chuck protecting the ball screw using some aluminum flashing. I then held the machined end fitting in the tail stock chuck and welded it to the ball screw. This worked well for holding everything straight. The bearing block holds 2 angular contact bearings to take radial and thrust loads in both directions. There is a smaller diameter bore that creates a step in the middle of the block that both bearing seat against. There is a second 3/4" thick plate that goes between the bearing block and the machine base to provide for more y axis travel.
    This picture shows the X-axis ball screw assemble. Like the Y axis, the threaded end fitting is welded on. The other straight end of the ball screw was machined on my lathe using an indexable carbide tool. The left bearing block is very similar to the y axis one to take thrust loads and radial loads. The other bearing block uses a sealed ball bearing and only takes radial loads at that end. Part of the turned stub protrudes through so that I can still provide a handle for manual milling. If I decide to incorporate that feature. Again one ball nut threads into the block that bolts to the saddle and there is a spring and another ball nut that take up the backlash. You can see a little block that prevents this ball nut from rotating.
    This is the machine base and you can see the cutout for the y-axis nut to protrude through. I had to open this up to make clearance for the new bracket. I also gained a little bit of Y axis travel.
    This picture shows the Y-axis ball screw assembly in place ready for the saddle to be installed.
    Here the saddle is installed with the X-axis ball screw in place. This part has to be mounted and aligned before putting the saddle on the base as the screws install from underneath.
    This is the machine with the table installed, the gibbs adjusted, and the bearing preload adjusted.
    This was a trial install to see how everything works dry. I still have to grease the bearings and the screws, but checking with the dial indicator, the backlash is zero in both direction and the movement is very smooth. With the gibbs adjusted, I can move either axis just by grabbing the 3/8" diameter end of the screw and turning it with my fingers. Needs a pretty tight grip, but I can do it. With the machine disassembled, I found that those Chinese craftsmen apparently didn't know the meaning of de-burr. There were many sharp edges that were contributing to stiff movement. I dressed those out and the machine movement is better than it has ever been.
    This last picture shows the motor mounts that I have made for the machine with the NEMA 23 motors I already had. They are way overkill, but I had the 1-3/4", 1/8" wall tube and the steel plate already. As a matter of fact, I had all of the material I needed to make all the mounts. The tube ID was perfect for the locating step on the NEMA 23 motors and it protects the unsealed angular contact bearings in the bearing block.
    As you can see in this picture, the motor for the Y hangs off the table a lot. I wanted to do direct drive, but I may later install a cogged belt drive and flip the motor around to keep the motor within the confines of the table.
    Next step is to clean that messy bench and order the real motors. I have the drivers, BOB, and power supply on the way. Shouldn't be long now to get a 2-axis CNC. I will machine the Z axis drive parts using the X and Y axis CNC with machine pauses in the G-code for manual positioning of the Z.
    I'll update when I get more.
    Registered Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    Looks good:})
    On mine, when I started to do cnc, the X axis all of a sudden started showing lots of backlash. I found the mounting block for the ball nuts would loosen up and actually move. I ended up making a mount with extended "ears" and after getting it aligned, I drilled and pinned the block to the saddle. No more movement!
    Art
    Feb 2012
    England
    I don't wish to put a spanner in the works but.....there's only two axis here,are you not supposed to have the turret a third axis?
    Jan 2005
    Quote Originally Posted by HorridHenry View Post
    As I said, to start with, I will do the X and Y axes. Once I get the machine running in X and Y I will use it in CNC mode to make the parts I need for the Z axis.
    Jan 2005
    Quote Originally Posted by Bubba View Post
    Looks good:})
    Unfortunately, the pocket where the X axis block mounts is pretty tight. No room to extend the ears in the fore-aft direction. Side to side i was limited to the thickness of the aluminum stock I had on hand. I may be able to drill and ream for one dowel pin in the centet between the 2 bolts. I'm sure I will have the machine apart again. Once I get it running I will figure out where to mount limit switches, wire anchors, etc. and will likely put some kind of lube system on for the ways. I'll see what I can do about that dowel then.
    Gold Member hoss2006's Avatar
    Apr 2006
    Very nice double nutting.
    Pictures of the mill put the drive/motor selection into perspective, the table isn't quite as huge as some may have envisioned before.
    570's should have no trouble with it especially when you go to 50V.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jan 2005
    I was planning to just put a y-axis way cover on to protect the y axis ball screw, and since the x-axis screw is under the table I wasn't going to do anything there. I will still do that much, but the more I think about it, I think I would like to put some kind of wiper on the ball screw nuts. I have seen it mentioned about using hot melt glue as a wiper. Does this work well? Is it as simple as lubricating the screw and putting the hot glue on the nut?
    Mar 2004
    LaGrange, GA USA
    You can see how I did some for mine here:
    My CNC Homepage
    Art
    Jan 2005
    My CNC Homepage
    Those look good. I like those kind of home brew solutions. I also liked your ball nut setup. Mine should work, but I'm not sure if I have enough preload forcing the nuts apart. I only have about 60 lbs which I am worried won't be enough. If you don't mind, I think I'm going to modify mine to take a setup like you have. I'll wait until I have the electronics hooked up so I can CNC the parts, but I really like your solution since I should be able to get just about any preload I want.
    Registered arizonavideo's Avatar
    May 2008
    Just crank the ball nut spring until it is flat. I bet that will be more like 150 pounds.
    You only need the smallest amount of give in the spring like .002" or so, the metal flex in the spring even when flat should have enough travel.
    Mar 2004
    LaGrange, GA USA
    As far as imitating my setup, have at it. I put it up there to share with anybody that wanted to use it. Also it might give someone an idea on how to better improve it!
    As for your preload, attached is a chart that I borrowed from the Original Industrial Hobbies site back when Arron had the company. As you can see, you don't really need massive amounts of preload force. As I remember (senior moment) I have between 80 and 90# of preload on my 5/8" ball screws. Remember, you might flex a spring pack on a roughing cut due to cutting load, but the loads on finish pass are quite light. If you have an excessive amount of preload, you will shorten the life of your assembly.
    Attached Thumbnails Attached Thumbnails HF round column mill drill build-preload_chart.jpg
    Art
    Feb 2006
    Pre-load should exceed the highest machining force. A double ball-nut assembly will provide zero backlash ONLY as long as the spring pressure exceeds the machining force. Typical pre-load for a 5/8" screw is about #150. Even if you double that, on a hobby machine you won't live long enough for wear to be an issue.
    Regards,
    Ray L.
  • Page 1 of 3 123 LastLast
    1. Round Column Mill/Drill motor sizing
      By APD_CNC in forum Benchtop Machines
      Last Post: 11-07-2010, 02:48 AM
    2. Newbie- Round column build
      By .RC. in forum Benchtop Machines
      Last Post: 10-11-2010, 06:28 AM
    3. Round column mill?
      By bearwen in forum Benchtop Machines
      Last Post: 01-06-2010, 09:02 AM
    4. Round column mill
      By SCROMAL in forum General Metalwork Discussion
      Last Post: 06-18-2006, 01:23 PM
    5. HARBOR FREIGHT small round column mill to a square column conversion.
      By motomitch1 in forum Vertical Mill, Lathe Project Log
      Last Post: 12-01-2005, 11:24 AM
