So over a distance of about 20 inches you are worried about .001.that's already pretty dang precise. have you taken a micrometer and measured something .001 thick? a piece of paper is 4 times thicker. how long of a part do you normally work on, if it's 10 inches the error from side to side would be even less. too many people see numbers on a dial and if it isn't zero for everything they think it's no good. you need to learn about acceptable tolerances. you are better leaving well enough alone, you are likely to make it much worse scraping away yourself but it's your mill and you gotta have zeroes right.
bill
LinkBack URL
About LinkBacks
I have an old abused enco mill crosslide that is useless without some TLC ill start with that. But hopefully Ill be learning from nick in Germany who is a pro at scraping..this guy
) Come Friday morning Ill be able to try that and any other suggestions that come up in between. The machine is bolted to wood at the moment but its not much larger than the base maybe 6" all around bigger and around 2" thick which sits on a large table. I can try and source a proper base plate for the table and get it there by Friday. When the gibs were in their loose position I could fit a piece of printing paper in the gap between table and the slide at the op of the extend end(being lifted). Also I got about .5mm deflection by lifting and then pressing down on the end of the table(with y locked down but not the x). Im eager to at least order a nice granite measuring base and blue the control surfaces and the camel back. The granite plate I can get from
