I cut a little bit of 303 on my X1, and it was as much fun as cleaning a toilet. If you tighten everything up good, lock the head and quill, it might work. The problems you're going to run into are that light DOC cuts lead to work hardening, and anything deeper will push the mill's rigidity and torque to the limit. I might try getting a slightly smaller cutter to reduce the torque. Either way I would bet money you're going to make some scrap and break a couple endmills figuring it out :P
LinkBack URL
About LinkBacks
