Results 1 to 11 of 11
Thread: Anyone play with the Chinese "router fourth axis" yet?
    Dec 2010
    Found this on Ebay... If the spindle for the thing will deal with the stress, I'm wondering if it might be interesting to mount a larger stepper?
    CNC Router Rotational Axis, the 4th Axis, A axis for the engraving machine 1650 | eBay
    Gold Member hoss2006's Avatar
    Apr 2006
    I posted that a while back, I don't know if anyone has taken the "plunge" yet.
    That's who I got my pendant from so they aren't bad to deal with, ok shipping speed.
    With a 50:1 ratio a bigger motor isn't going to gain much, it should already have tons of torque.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Dec 2010
    Hmm... I might... I'm basically thinking, however, that if I can find a spindle that I can use with an R8-mounted chuck, that could also work. I'm not needing huge, and I am a little worried about the worm gear backlash/wear that Warfield speaks of...
    Apr 2006
    Yeah that's what makes a harmonic drive like this is supposed to be so desirable, no backlash.
    A typical rotary table 4th axis will need adjusted from time to time and even then backlash isn't likely to be zero.
    Hoss
    Dec 2010
    I'll be machining steel, with the largest parts approximately 1.25" diameter, and if I need to, I can deal with smaller cuts (as long as I don't get into the realm of surface hardening). I'm hoping that I can work out a "real" fourth axis, so that I can do real curving cuts, rather than just an "indexer" type of thing (which is what we've got in the shop right now).
    Apr 2004
    Oakland CA USA
    The no-backlash feature sounds good, if it really works. But I wonder if it will mount any other chucks besides that 3-jaw - most of the stock I use is square or rectangular, not round.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Apr 2006
    Looks like a typical lathe chuck on there Andrew with the mounting studs thru the faceplate
    so I'd imagine a 4 jaw chuck would fit too at least with an adapter from LMS.
    Hoss
    Dec 2010
    Okay, looking like I'm going to be doing one in the next few days... I'm just hoping that it is overall rigid enough to work with steel parts. And I may be looking for a four jaw at the same time too...
    Nov 2009
    washington state usa
    Cool let us know how it works out for you!
    It's a nice compact unit from the pics.
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
    Jul 2010
    Any other word on this?
    I've been eyeing it for a while, and am unsure if I should pull the trigger.
    adrian
    May 2005
    canada
    This 4th is a topic in the DIY router forum
    linky:
    http://www.cnczone.com/forums/diy-cn..._4th_axis.html
    Buyer adapted a fancy chuck, unclear if min-lathe chucks are a bolt-on affair
    Anyone who says "It only goes together one way" has no imagination.
    1. "low end" HF Spindle or "high end" router for about $1000?
      By biomed_eng in forum DIY CNC Router Table Machines
      Last Post: 01-06-2012, 01:15 AM
    2. Taig Mill Table "play/slop/lash"
      By surrealism in forum Taig Mills & Lathes
      Last Post: 06-29-2010, 04:54 PM
    3. "Plug and Play" CNC controller.
      By mike@mikebeck.o in forum Hobbycnc (Products)
      Last Post: 10-30-2007, 03:46 PM
    4. Help! Fourth axis "vanished"
      By jasonwinters in forum SprutCAM
      Last Post: 11-15-2006, 11:30 AM
