Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 38
Thread: Something wrong with "Z" axis
  1. #25
    Feb 2011
    Moneypit but I put new software installation with on my laptop with default settings and still have the problem
    Sent from my HTC Sensation 4G using Tapatalk 2
  2. #26
    Feb 2011
    Quote Originally Posted by satovey View Post
    1. The driver that the motor is connected to may be causing the problem.
    *** Try hooking the motor up to one of the other drivers
    and see if you get the same or different results.
    Okay I fixed it. All I need to do is swap the cables from X and Z motor controllers and now everything works like before.
  3. #27
    Mar 2012
    Here
    Great to hear.
    But it makes no sense or we were missing more details.
    Signals where going to wrong axis ? unlikely.
    Dropped steps ? Now the issue has now been moved to the X axis.
    Manual jog worked ok.
    MP*10
  4. #28
    Feb 2011
    MoneyPit everything works like a charm. Jog,X axis ,Z axis. I have no idea what might been wrong. I don't think that the signal really matters because I calibrate each axis separately.
  • #29
    Mar 2012
    Here
    Smile
    Wierd Science.. Murphy's Law.. Sun Spots..
    Only thing important is it's back to normal.
    MP*10
  • #30
    Feb 2011
    Okay. Problem came back. Now on X axis. I setup the gcode to run the same path for about 12 times and going deeper .030 each time. When its repeating the path 10th time it move out of path.
  • #31
    Oct 2009
    Sounds like a bad wire connection or a bad hardware item if it changed to other after swapping.
    The fact that it moved by swapping wires, then went away for a bit, implies a loose something.
  • #32
    Feb 2011
    might be. but why it is working fine for about 10-15 min and then suddenly goes bad. I think there might be a problem with the motor driver.
  • #33
    Oct 2009
    Indeed, are they hot to the touch? Do they have any airflow?
    If not, the wires can also be under tension or moved as the Mill moves and that could be re-loosening. I would have thought it was internal to the motor, but you eliminated that.
  • #34
    Feb 2011
    yeap. motor is fine. I'm also thinking of the USB plug by the controller board. I did damage it little bit when I was trying to drill a hole in the case . But it looks like the problem went from Z axis to X axis when I swap the cables. Which makes sense to me that the driver is causing troubles.
  • #35
    Oct 2009
    When it works and then it doesn't, more often then not its heat. Or its burning out internally as load increases beyond its broken-ability.
  • #36
    Feb 2011
    I installed a heat aluminum bracket on each drive and screw a small fan on top of that bracket so it will take the heat out. Also I have a fan in the case that will remove the hot air from the case
  • Page 3 of 4 FirstFirst 1234 LastLast
    1. Replies: 0
      Last Post: 12-20-2011, 07:20 PM
    2. "NEW" 1/8" 5 FLUTE CARBIDE END MILL "AlTiN"
      By CNCadmin in forum EBAY ADS
      Last Post: 11-06-2011, 02:00 AM
    3. Need Help!- Thread Milling using "C" axis no "Y" on the machine
      By tejano4life72 in forum Mori lathes
      Last Post: 07-19-2010, 03:59 PM
    4. Problem- "wrong program data" when file transfer????
      By spock in forum Bridgeport and Hardinge Mills
      Last Post: 07-28-2008, 06:59 PM
    5. Fanuc O-MC Alarm 405 "Z axis wrong (ZRN)"
      By JSaindon in forum Fanuc
      Last Post: 09-19-2007, 11:22 AM
