Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 41
Thread: CNC Conversion Woes!
  1. #13
    Apr 2007
    I have always used the same speed and accel values for all 3 motors. I was not interested in pushing each drive to max so I just left the values the same.
    Its clearly loosing steps during dir/accel changes but still unclear why. Some things I'm investigating are:
    1) win 7 lpt port issues. I'm going to shut down as many processes as possible and see if that makes a difference.
    2) grounding issues and/or noise on the lines. Both the PC and CNC are connected through a power surge protector.
    Is anyone else using G203V drivers? I never adjusted the trimpot on these since the motors are quiet when idle and never get very hot even after full test runs. Is it necessary to adjust them for proper operation?
    -Leo
  2. #14
    Registered arizonavideo's Avatar
    May 2008
    I have the 203 and you must adjust the trim pots to counteract the ring that all steppers have.
    Follow the instructions or just changes speeds until the motors are loudest and adjust the pot until they quiet down. You can hear the ring fairly easy.
  3. #15
    Registered LongRat's Avatar
    Apr 2005
    UK
    In my experience it will be pretty obvious when the machine is running if any steps are being lost. The sound of the motors will change and it will be pretty unpleasant.
    LongRat
    www.fulloption.co.uk
  4. #16
    Apr 2007
    Thanks for the input arizonavideo. Right now I'm rewiring the grounds so they all meet at one point. I had the 203s gnd daisy chained. I will tune the 203s once I get that done.
    Someone in the MACH forum suggested connecting the grounds to earth ground essentially bypassing my surge protector. Is that a good idea?
    @ LongRat, I have been able make the motors loose steps when I turn my MPG very fast so I am familiar with the sound, but never heard the same sound during the cutting. Then again I'm still getting familiar with all things CNC so what may sound normal to me may in fact not be.
    -Leo
  • #17
    Tinkerer
    Nov 2009
    Quote Originally Posted by LacL View Post
    This is a common and accepted practice, known as "a star ground".
  • #18
    Dec 2009
    What are you using to make the GCode? I would doubt there is an electrical noise issue that is causing you to cut the exact same undersize each time, nor would I see it being lost steps. Seems like something is off in the production of the code to get a repeatable error like that. What software did you use to go from drawing to CAM to GCode.
    The min/max X values I see are:
    -0.3968 / -3.214
    That's a difference of 2.817" between the tool paths then subtract the end mill that's 2.6922" of material between the cuts. Is that the X extents dimension of the part? If not then your tool path isn't right. Lets start there. What is the part supposed to measure in the X direction and what does it actually measure?
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  • #19
    Registered Mad Welder's Avatar
    Jun 2011
    Ireland
    The part which is a square is 45 mils too small on both x and y once cut.....every time..
    Hi there Lacl, I normally run for help to the guy's here too as I’m not at this long either but guy's is there any chance that the Inches/MM settings are getting mixed up here as all calibration measurements are referred to in US imperial (inches) but the repeatable error is suggested as 45 mils (mm's) or is mils another aphorism for a commonly used imperial measurement term?
    Eoin
  • #20
    Mar 2012
    Quote Originally Posted by Mad Welder View Post
    Eoin,
    The "mil" is a milli-inch = 0.001". It's a commonly use term in the US....so he's saying the part is 0.045" too small.
    Meddle not in the affairs of Dragons - for thou art crunchy and taste good with ketchup!
  • #21
    Apr 2007
    Additional things I tried, but no change in results.
    1) I ran MACH3 in XP SP3 mode.
    2) I turned off everything I could think of in windows including firewall and virus checker (after disconnecting from the network of course).
    3) Wired GNDs to one junction (star ground).
    4) Tuned the 203 drivers as per manual.
    5) Made a small offering of blood when I accidentally scratched my hand on the end mill.
    Quote Originally Posted by photomankc View Post
    -0.3968 / -3.214
    This was the first thing I verified when I first noticed the problem. The values you posted are not the extents. If you scan through the file, you'll notice the min/max values are -0.3968/-3.6032. That's a difference of 3.2064" minus tool dia of 0.125" and that should leave a part that is 3.0814". Actual part should be 3.081" and I consistently get 3.036" +/-0.002
    The values on the MACH3 DROs match those in the file during the test runs at the extents.
    -Leo
  • #22
    Gold Member hoss2006's Avatar
    Apr 2006
    What version of Mach 3 are you running? The fact that you said the axis calibration wasn't working points to the problem.
    The dros could match the gcode as it's running but the machine isn't physically moving the same as the dros.
    Try the newest lockdown version and do the again.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  • #23
    Jul 2006
    here is a suggestion, in ports and pins, enable sherline mode. Then try again.
  • #24
    Tinkerer
    Nov 2009
    Have you gone thru all of the Mach optimization steps?
  • Page 2 of 4 FirstFirst 1234 LastLast
    1. Need Help!- AVHC Woes
      By pirateducky in forum Torchmate
      Last Post: 07-21-2011, 08:39 PM
    2. Z Axis woes
      By Thorpydo in forum Benchtop Machines
      Last Post: 09-29-2009, 12:37 PM
    3. RE- My woes with CNC......
      By kbillan in forum Taig Mills & Lathes
      Last Post: 01-16-2009, 05:22 PM
    4. Bob CAD woes
      By Mr. LocoMartin in forum BobCad-Cam
      Last Post: 01-25-2008, 03:18 PM
    5. Wiring Woes.....
      By Normsthename in forum General Electronics Discussion
      Last Post: 01-03-2007, 04:38 PM
