I am interested in buying a milling machine and converting it into a
CNC mill. I look forward to figuring out and executing the conversion as well as having a tool that I can use to make parts for a range of projects.
I am interested in your input as to which brand and/or model of mill I should buy for the conversion.
These are some criteria that I have come up with (though I would be curious if you could argue why a criterion doesn't make sense or suggest other criteria that I'm missing)
- bench top (I would like to be able to move it with 2-3 people: I've seen some tempting Bridgeports on craigslist, but can't figure out a way to get them from the seller to my garage without paying a couple hundred dollars to rent a flat bed truck--not to mention incurring a big expense any time that I move in the future)
- capable of doing metal working: anything from aluminum to stainless steel
- 110v single phase (I would like to use it in the house I live in and potentially in future houses without having to re-do the wiring)
- 3-4' wide table (I don't want to find myself in a situation where I want to make a part bigger than my mill can bear)
- naturally, great build quality (I would like to use the mill to make relatively high precision parts for the rest of my life).
Now for some features that I would love to have. Admittedly, I would be shocked if I could find a machine that has them that does not cost a fortune. Though, it would be nice to pick up a mill that wouldn't make it a nightmare to add them.
- 5 axis
- self-changing tooling
I would be up for paying up to $2000, but would prefer to be in the $750-1250 range.
What machine do you suggest that I buy?
