Results 1 to 7 of 7
Thread: controller box questions
    Registered maker of things's Avatar
    Mar 2012
    How large of a box do I need to enclose the controller components? I'm planning on a c10 bob, (3) kl-5056 stepper drivers, a kl-600-48 power supply and some sort of fan(s). At some point in the future I will add a 4th kl-5056.
    Searching for this info has produced too many hits, or maybe I'm not working it right.
    -Jon
    Gold Member hoss2006's Avatar
    Apr 2006
    A PC case is enough room and they are common affordable choices, those and server boxes, etc.
    That's what they're for, housing electronics and you can already have a useful power supply and fans with some.
    For that pro look you can get a Nema case from many places like here.
    Enclosures Products
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Feb 2006
    Whatever you do, decide how much space you need, then double it. It will not only make wiring easier, but give you room for growth. Invariably, if you buy a box that you think is the "right" size, it WILL end up being too small, probably before you're even done with the initial build. My E-box enclosure is a 24" x 24" x 12" NEMA12 enclosure (found for $99 on E-Bay!), and it's now barely big enough, after three years of improvements and added features.
    Regards,
    Ray L.
    Apr 2006
    Quote Originally Posted by maker of things View Post
    Keling (Automation Technologies Inc) Shows an efficient layout of the components you list including 4 drivers in one of their 17x13x5 control boxes.
    http://www.kelinginc.net/Controlbox.pdf
    Not much room for expansion in something that small so you might want to plan ahead for adding additional components someday.
    I went big enough so I had room for drivers 5 and 6, the spindle motor controller and several other little boards and relays.
    Hoss
    Dec 2003
    The Kelling unit does not seem to abide by the more safe and code necessary hardware E-stop?
    Looks as though it goes into the PC and no hardware disconnect of spindle or drives?
    I agree with Ray, there never seems to be enough room at the end of the build, I usually lay all the components out and calculate the size of the backplane I might need.
    Ebay is a good source of industrial enclosures.
    Apr 2006
    I showed the keling pdf for physical layout purposes only.
    The OP's question wasn't about wiring, yet, I'll leave those questions for the experts.
    Hoss
    Mar 2012
    Thanks for the info. I have a pc box so for the price sounds like a good starting point.
    I ordered bob, steppers/drivers, estop and ps from Keling (automation technologies) last night. I still need 3 limit switches and a relay for the 110 stuff.
    -Jon
    1. M32 controller questions..
      By tnik in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 07-10-2012, 05:00 PM
    2. controller questions
      By scrambled in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-31-2011, 10:50 PM
    3. Motor and controller questions
      By sYmbot2 in forum CNCzone Club House
      Last Post: 10-11-2008, 01:43 AM
    4. Questions on the original UHU controller
      By southernexplore in forum UHU Servo Controllers
      Last Post: 08-16-2008, 01:52 PM
    5. Some basic controller questions
      By Mwilhelm10 in forum General Electronics Discussion
      Last Post: 10-09-2003, 01:45 PM
