The full DMM 400w AC servo kit arrive in lightening fast speed... 3.5 days from Canada to Australia, couldn't be happier...
First impressions of the kit was very good. Well packaged and everything was there. The motors were smaller than I imagined but should still work just fine!
Also picked up a bluetooth pendant. Loaded it into Mach 3 and seems to work great. A little laggy but nothing too bad...
looking good. have you spun up the ac servos yet? i bet they are smooth. What drive ratio are you planning on using? Are you going to get ballscrews or just stick with the standard leadscrews and use backlash compensation?
Already have some 25x5 ballscrews left over from the router project that got scraped so I will just use these... Will also double nut them with a preload on the 2nd nut for automatic adjustment. Havn't made a decision on the ratio yet. But will be some where around 2:1 or 3:1 or somewhere in between.
Havn't fired the servos up yet... Waiting to get the control cabinet so can I wire everything up...
Spend last weekend wiring everthing up into a cabinet Here . Got all the servos running, pretty happy with them. Microstepping on the drives works very well.
I am just finishing off models, then i will work out the exact screw lengths i need. where did you get screws from? locally or imported?
keen to see a video of that pendant in action when you get motors running.
The thrust bearings are completely unnecessary. The whole point of using A/C bearings is that they handle both radial and axial loads. And do NOT use bellevilles to pre-load bearings. Either the pre-load will be so high that you'll have high friction, and reduced bearing life, or so low that the bellevilles compress further under load and you have backlash. The pre-load should be provided by shimming or some other rigid means of adjustment. Also, the A/C bearings must face opposite each other.
