This lathe has an inch lead screw, so you don't use the thread dial when cutting metric threads. You have to leave the half nut engaged until the threading process is complete. At the end of each pass you stop the lathe while quickly backing out the tool. You then reverse the lathe to run the cutting tool back to just before the beginning of the thread, reset the tool for the depth of the next pass & make the next cut -all with the half nut still engaged.
Hope this helps.
Tim
LinkBack URL
About LinkBacks
