The bench setup part is a bit disappointing as most of the world don't use R8 or straight shank TTS-style holders for
CNC. It's easy to get a CAT40 tightening fixture, but R8 is harder.
For the time being, I prefer collet chucks that have wrench flats. I can lock them up in a vise with soft jaws and put some serious torque on one.
Down the road, I was recently over at a friend's shop who has a Romi
CNC toolroom lathe. We took some 4140 round and put an R8 taper in it (so easy to do with a
CNC lathe). It will eventually become both a tightening fixture and a tool setting fixture as the top and bottom are ground parallel so it can sit on a surface plate while I use a height gage to measure tool height.
Cheers,
BW
