Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: School me on ER collets...
  1. #13
    Jan 2009
    Quote Originally Posted by 1HobbyMachinist View Post
    I guess I could do that. I could make a wrench to tighten my ER collet chuck, which I bought to hold endmills better so I could make tslot nuts and toe clamps for my 3 sine vises so I can make straight edges so I can hand scrape them into master surfaces so I can rebuild my mills so I can begin converting them to cnc. What's one more project right?
    Hell, I just started working on a spindle lock since I just can't see paying $120 for one when I've got all the materials just lying around.
    Sooner or later I'm going to get to the root of this project...
    Sounds like we both are preaching to the choir.
    Last week it was making my own thread mills.
    This week its threading fixture jigs with my thread mills.
  2. #14
    Jan 2012
    Quote Originally Posted by Dennis Rech View Post
    That sounds pretty neat. I never heard of them before I googled it. What are yours made of? Do you heat treat them?
    Chasing tenths is hard...
  3. #15
    Jan 2012
    So to those of you who use R8 - ER collets, how do you torque them down?
    I can always just use the old TAF torque spec, but how would I do it properly?
  4. #16
    Feb 2009
    Rigo fix collets are by far the best, they come with a torque spec sheet. Different torque for different size collets. They have a crows foot style wrench and a very expensive torque wrench made for it. Just FYI.
  • #17
    Jan 2009
    I made an 11 tpi one out of a broken 5/8 x 11 HSS tap. Cut the broken end off with an abrasive chop saw leaving about 12 cutting edges and ground off two of the three flutes. It worked well except the remaining fluted threads were about 1/4 inch long and the pitch angle left a slightly wide cut thread. Ground off about 1/8 inch of the trailing edge of the flute and thinned the trailing end of the cutting surfaces with a Dremmel with a 1 inch thin abrasive wheel. It now works great. I use it on 1 inch diameter mild steel shafts and matching 1 inch aluminum holes.
    I have a Centroid CNC mill and thread milling is built into the conversational programing.
    I also have made a single point thread mill by milling a 3/8 inch flat on a 4 inch long piece of 3/4 inch diameter drill rod. Milled a triangular pocket into the flat the same shape and depth as the 60 degree carbide inserts that came with some Enco lathe bits. The tip of the insert sticks out about 1/8 inch. Brazed the insert into the pocket. When it breaks off or wears down, I'll just heat it, rotate it 60 degrees and braze it back on. I single point 6 TPI male and female threads on two inch shafts and pulleys with it. Again, the Centroid system includes single point thread milling with multiple passes.
    It took about 15 minutes to grind down the 5/8 inch tap and probably 45 minutes to make the single point one.
    Dennis
  • #18
    Registered Arich0908's Avatar
    Oct 2009
    BridgePort , CT
    I forgot why I even came here in the first place . I wanted to make something.... That doesnt even matter any more.
    I have a ER32 and love it.
  • #19
    Dec 2010
    With my 704, I just hold the spindle in place, and tighten with the spanner wrench. Seriously, you don't need a huge amount of torque if you are using stuff that is within the correct dimensional range.
    With the bridgeport, I just stick it in back, and torque away...
    That said, since I mostly am doing small cutter stuff, I've been using DA300 collets - Just stick the holders in a high quality/low TIR 1/2" R8 holder, and go for it... Main reason for that is that I can get a LOT closer to the workholding while still keeping a lot of tool shank in the collet.
  • #20
    Jan 2012
    Well, I got the bearing nut and a wrench for my ER40 chuck from Maritool. I like it, it definitely feels like I can torque it down better.
    I also finished my spindle lock project. I am sharing a few pics of the complete work, but I admit, there's not a lot to see. I basically copied the idea from Fignoogle's product. I made mine from 1" steel plate though, (just because I had some lying around) and I think mine might be just a little bit stronger...
    Overkill is my specialty
    I have a nice knob on order, it should arrive within the week, but even without it, the spindle lock functions fine.
    Right now I'm trying to decide if it's ok to tighten my ER40 chuck with the spindle lock, or if I should clamp it in a vice. I think the spindle bearings can easily take the strain, and I know my lock can. So I think tightening in the spindle should be just fine... Opinions?
  • Page 2 of 2 FirstFirst 12
    1. School Boy
      By Getter-Done in forum CNCzone Club House
      Last Post: 06-28-2010, 10:17 PM
    2. BP CNC Retrofit---for my school lab
      By 2Springers in forum Bridgeport and Hardinge Mills
      Last Post: 02-26-2010, 05:03 PM
    3. Old School Calibration
      By kenbarra in forum Calibration and Measurement
      Last Post: 04-30-2007, 08:16 AM
    4. New cnc school
      By warnercnc in forum CNCzone Club House
      Last Post: 02-19-2007, 11:25 PM
    5. School in Socal?
      By Do.kevin in forum Employment Opportunity
      Last Post: 01-18-2007, 02:12 PM
