Results 1 to 11 of 11
Thread: G0704 Z axis conversion
    Nov 2011
    Hi.
    I got G0704 and want to connect Z axis to steper motor as it shows on attached drawing and encountered a problem, since unable to figure out exact tap size on the end of Z axis as it shows on the attached picture.
    According to G 0704 manual thread size should be M16-2 metric. But it's incorrect, because I measured it myself and it showed as M16-1.5 or 5/8-18. Please help me with correct thread size, so I can order Shaft Collar per drawing.
    Attached picture was found on the net and I cant find the source anymore.
    Thank you.
    Feb 2006
    Is there a reason you can't simply measure it?? That's the surest way to KNOW what the actual thread on your particular machine is....
    Regards,
    Ray L.
    Oct 2010
    Well i dont quite see the problem. if you measured it and it is M16x1.5 then i guess it is such. go on ahead with your plans
    Nov 2011
    Correction: I think it is 16-1.5 or 5/8-18, since I cannot measure it. 3 stores I visit were unable to help me to check correct thread size.
    So, if someone had to deal with G 0704, please help me to find out thread size. Then I will be able to order necessary parts online.
    Feb 2006
    There are NO imperial threads on these machines (other than drawbars, and a very few other specific places where interoperability is required), so it will NOT be 5/8-18. If you really want to make sure buy a 16x1.5 nut and see if it fits....
    Regards,
    Ray L.
    Gold Member hoss2006's Avatar
    Apr 2006
    Quote Originally Posted by pemko View Post
    It's M16x1.5, just pulled my old one out to check.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2011
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Thank you, Hoss.
    Do you know, by chance, where I can order Threaded Clamping Shaft Collar M16-1.5? Maybe somewhere in Chicagoland.
    Apr 2006
    It's fairly easy to find M16x2.0, mcmaster even carries them but Misumi USA seems to carry the M16x1.5 for $6.38.
    Shaft Collars - Threaded I. D., Slit | Mechanical Components for Assembly Automation - Misumi eCatalog part #SCSN16A
    Hoss
    Banned
    Mar 2009
    I like the design with the pinch collar. Not sure I've seen that yet.
    I would beef up that mounting plate though. Especially if you plan on making it out of aluminum.
    Nov 2011
    Hoss
    Thank you for a good hint, Hoss.
    I ordered necessary part from their site and it was delivered quickly.
    Thank you for the help.
    Stepan.
    Apr 2006
    Happy to help, you're welcome.
    Hoss
    1. New Machine Build- New G0704 - CNC Conversion
      By feederic in forum Benchtop Machines
      Last Post: 11-20-2012, 11:42 PM
    2. G0704 X axis conversion
      By pemko in forum Benchtop Machines
      Last Post: 02-27-2012, 09:07 PM
    3. G0704 Conversion
      By rcazwillis in forum Benchtop Machines
      Last Post: 07-17-2011, 10:27 AM
    4. My Grizzly G0704 Conversion to CNC
      By DrewSmith007 in forum Benchtop Machines
      Last Post: 04-11-2011, 12:42 AM
    5. Newbie- g0704 - conversion project
      By dsdmax in forum Benchtop Machines
      Last Post: 03-01-2011, 10:03 PM
