Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Thread: disappointed with Sherline and needing recommendation
  1. #13
    Registered judleroy's Avatar
    Dec 2006
    Stepper motors can be spun while Manuel machining but servos can't. Also you want friction while Manuel machining with ballscrews because they backdrive. They wouldn't stay put when you let go off the handles.
    Judleroy
  2. #14
    May 2003
    Complete package, contact me me for a better price than what I have it on ebay for....
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    Sorry if this is the wrong place, but, the G0704 did come up in the thread.
  3. #15
    Mar 2012
    Ah ha! Now I get it. That is something that I had not considered. I was thinking of converting the machine to ball screws a while back so it would be ready for CNC sometime in the future and was wondering why they did not just build them will ball screws in the first place. Obviously price is a reason also, but would not have cost Bridgeport that much more over what the acme screws cost.
    I guess you could get good results in manual as long as you always remembered to lock the tables or did not take your hands off the wheel.
    My concern was back driving the motors in manual for two reasons. One was the extra friction and the other was that when unpowered steppers are turned they kind of ratchet from step to step which makes it hard to do precise slow turns and stop exactly where you want. Also kind of gives it a built in vibration as you crank the handle which can give a bad part finish.
    The extra friction might negate the need for the brake if it is just the right amount.
    The ratchety turning might not be as much a problem as I am expecting with the bigger hand wheels on the BP.
    Thoughts?
  4. #16
    Tinkerer
    Nov 2009
    Disconnect all leads on the steppers (make sure they are not touching each other) and see about that rachet feeling. Should be much smoother. You wouldnt feel it on a BP anyway if using them manually. I cant imagine why anyone would go manual after the refitting. Just use an MPG/Shuttle Pro and do anything you want quickly and smoothly.
  • #17
    Mar 2012
    Looked at the Shuttle and also the VistaCNC pendants and I see what you mean. Having something like that probably would end my hand cranking days. Thanks.
  • #18
    Dec 2006
    Yea you willl throw handwheels out the door when you find how easy & good pushing a button works.
    Jess
    GOD Bless, and prayers for all.
  • #19
    Tinkerer
    Nov 2009
    or using the MDI line for a smooth feedrate
  • Page 2 of 2 FirstFirst 12
    1. Needing Help!!
      By Pklef in forum Employment Opportunity
      Last Post: 10-20-2010, 03:13 PM
    2. Needing Help
      Last Post: 10-20-2010, 03:06 PM
    3. New Guy Needing a Little help here
      By Shop_Smith_Popp in forum WoodWorking
      Last Post: 03-30-2009, 01:46 PM
    4. Needing help please
      By Larry Myers in forum G-Code Programing
      Last Post: 10-04-2007, 03:22 PM
    5. New guy needing help please...
      By studysession in forum Welding Brazing Soldering Sealing
      Last Post: 01-12-2007, 02:18 PM
