I would have thought it should be relatively simple to convert to Mach3 control, so long as it is still a parallel port connection to your breakout board.
If you can look in Fanuc software settings, somewhere, and take note of all ports and pins in use (step/direction, limits, spindle, etc) and replicate them in Mach3, you should be up and running in short order.
LinkBack URL
About LinkBacks
