Results 1 to 4 of 4
Thread: Quill Rotation - Problem?
    Nov 2010
    I have a CNC Masters Baron XL Mill (zay 45 square column derivative, I think) and I have noticed a good bit of quill rotation under heavier loads. In this conversion the quill is automated for the Z axis. I am looking at the manual and an exploded parts diagram and for the life of me, I don't see an adjustment to keep the quill from rotating so much.
    Is 10 to 15 degrees rotation of a quill normal?
    Does anyone know where this is adjusted?
    I will try to call CNC Master's tomorrow, but I wanted to continue working tonight if at all possible.
    Thanks,
    Russ
    Feb 2006
    On most machines with quills, the only thing that restrains the quill from rotating is engagement of the pinion gear in the toothed rack machined into the quill. there is often an eccentric adjuster to adjust the engagement.
    Regards,
    Ray L.
    Nov 2010
    Thanks Ray,
    That's sort of what I thought. The whole issue sort of becomes a sticky wicket when you are rotating that pinion to position your z axis.
    Russ
    Feb 2008
    I bought a HM52 over here in Australia and after receiving a replacement it was from a different manufacturer. The old one relied on the same set up as yours, but the new one had a slot in the quill and a pin. It would not be hard to machine a key way in and drill a hole in the casting and make the pin, but you would need another mill to do it.
    I have put up some drawing in the link below for other members with a mill like mine, as it has a horizontal spindle and it can all be done on the same machine.
    HM 52 quill slot - Woodwork Forums
    Dave
  1. Need Help!- Robot Flex-GL50 hand rotation problem
    By Karsue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-20-2011, 04:26 PM
  2. Need Help!- Problem with tight quill movement
    By laser3kw in forum Bridgeport and Hardinge Mills
    Last Post: 01-26-2011, 07:14 PM
  3. Coordinate rotation problem on MORI SEIKI TV40 MSC-802m
    By kpandy in forum General Metalwork Discussion
    Last Post: 03-16-2010, 08:36 AM
  4. Need Help!- G68 Rotation problem on Fanuc 180i
    By btdmfg in forum Fanuc
    Last Post: 12-04-2008, 07:58 PM
  5. Newbie- New benchmill purchase XJ-25 quill-spindle problem
    By cgabel in forum Benchtop Machines
    Last Post: 09-20-2008, 02:22 PM
