Allen
I converted an Orac lathe to Mach a couple of years ago but decided not to mix old with new except the 80v power supply as I percieved problems. I used a brakeout board frorm CNC4PC and Gecko drivers the support to iron out a few snags from both suppliers was very good. Motor speed is contolled by Mach using PWM, CNC4PC do an opto speed board. I found the more challangeing part was configureing the machine to Mach.
Good Luck
Mike
LinkBack URL
About LinkBacks
