Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Micromark X2 Motor and control board ID?
    Aug 2011
    Hello, I am trying to identify and get more information on the motor and driver board on my Micromark X2. Ultimately I want to add a spindle enable signal from my CNC computer and speed control if possible. For now knowing exactly what I have and what it could be replaced with is enough. I do have an Oscope and logic analyzer should I decide to really take a good poke at it.
    One of the things that bothers me is Micromark says that cutting or applying power with the speed knob not at zero will cause the board to burn up. Given that and its other limitations I would like to know what it really is and if it has some hidden features I may like or if it can just be swapped out with another board.
    Here are some pics:
    The board has the MCU on a daughter card in the upper left with some opto isolators.
    Thank you.
    Attached Thumbnails Attached Thumbnails Micromark X2 Motor and control board ID?-pcbsmall.jpg   Micromark X2 Motor and control board ID?-motorsmall.jpg
    Aug 2011
    Well not much of an ID but I did find out that LMS has replacement boards and a simple plug in board for controlling the spindle from a CNC controller:
    LittleMachineShop.com - CNC Spindle Control Upgrade Kit
    Feb 2006
    That LMS board is only for the SX2, which has a brushless DC motor. It will NOT work on the regular X2.
    Regards,
    Ray L.
    Feb 2006
    Don't go poking around in that controller unless you know what you're doing! That thing runs directly off the AC line, with NO isolation, so almost EVERYTHING is "hot". If you try to attach a scope to it, without an isolation transformer, you stand a good chance of blowing up the controller and/or the scope.
    Regards,
    Ray L.
    Aug 2011
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Thank you for the concern. I often have to express the same sentiment in another electronics forum I am on. My back ground is more in electronics than machining. I got into machining so I could cut better looking project boxes! You are correct, my scope is not rated for direct contact with mains. It is only a class II measurement device. Some day I hope to own an isolated variac (or combo isolation xformer/variac.)
    Aug 2011
    Regards,
    Ray L.
    Mine is the SX2 with brushless DC motor, I did not know that designation till LMS pointed it out.
    Feb 2012
    England
    Heh?
    Sx2 is the x2 isn't it? the S only stands for Seig and looking at the board fitting instructions its going on the same board as the OP's
    http://lmscnc.com/instructions/4213C...UpgradeKit.pdf
    Dec 2006
    His does happen to be the same thing, but earlier and maybe even different brand X2 use to run a DC/ brush motor. His is the brushless setup so he could order the CNC control board and be going.
    Jess
    GOD Bless, and prayers for all.
    Sep 2011
    Quote Originally Posted by HorridHenry View Post
    Heh?
    No, it probably stands for "super" or something. I have an LMS SX2 and it has a more powerful brushless motor and seems to be a bit more solidly constructed. The harbor freight x2 for whatever reason seemed more spindly. It may just be because it mine and I think all my stuff is more awesome than other peoples stuff lol
    Feb 2012
    England
    Feb 2006
    Heh?
    No, it is not. The SX2 is the "Super" X2, which has a brushless DC motor, in place of the brushed DC motor of the standard X2. It has a rigid column, in place of the tilting column of the standard X2. It has longer travels than the standard machine. It does not have the noisy geared head of the standard X2.
    Regards,
    Ray L.
    Registered Arich0908's Avatar
    Oct 2009
    BridgePort , CT
    I believe a direct replacement is a board from KB I believe? KBMM 125? Something like that...
  • Page 1 of 2 12 LastLast
    1. Need Help!- I have shorted my motor control board
      By ceefna in forum Stepper Motors and Drives
      Last Post: 02-27-2012, 12:56 PM
    2. Replies: 6
      Last Post: 03-13-2011, 10:58 PM
    3. Sieg C2 motor control board schematic?
      By HankMcSpank in forum Mini Lathe
      Last Post: 09-09-2009, 04:13 AM
    4. Need help to locate stepper motor control board plus driver
      By Techbuilder in forum Stepper Motors and Drives
      Last Post: 10-16-2008, 09:53 PM
    5. Need help to locate stepper motor control board plus driver
      By Techbuilder in forum DeskCNC Controller Board
      Last Post: 10-14-2008, 08:11 AM
