Double, tripple, and on, and so forth, check the change gears. I had the same issue and It came down to having the spacer on the wrong side of the gear on the leadscrew shaft. IIRC the spacer has to be changed from the position used for power-feed and it wasn't obvious from the photos.
LinkBack URL
About LinkBacks
