Results 1 to 8 of 8
Thread: 3d printer/CNC mill
    Jul 2010
    3d printer/CNC mill
    Has anyone added a 3d print head to their CNC milling machine yet?
    I see a lot of threads of people building or buying 3d printers, but if you already have a CNC machine, is not almost trivial to just add a 3d print head to the side of the Z-axis and start printing parts?
    Gold Member hoss2006's Avatar
    Apr 2006
    Yeah, if you read thru those threads you'll see it was discussed. I gave links to some folks that did that to a Tormach and we talked about adding the same to a number of mills and routers.
    Thing is it can take hours to print parts and you'd be tying up your milling machine all that while.
    Seems better to have a standalone printer that can be printing in the background while
    you use your mill for more important stuff.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Registered mhackney's Avatar
    Feb 2004
    "more important stuff" like building a larger 3D printer!
    I actually built an extruder last year with the idea of attaching it to my mini mill. But, that machine was always in production making parts for my reel kits so I never had time to try it. Given how inexpensive these little printers are - especially the H-1 kit from SeeMeCNC that I am building - it just didn't make sense to tie up my mill.
    cheers,
    Michael
    Reelsmith and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com
    Tinkerer
    Nov 2009
    mhackney is probably correct however the idea had been talked about for quite a while. If I wasnt so lazy (and lacking of the necessary knowledge) it would have been done by now. I have the heated bed, the extruder/hotend, separate controller for the temp of both. At this point I realized I also have 3-4 existing projects that need love.
    My question for mhackney is, dont you believe the positional accuracy and rigidity of an actual machine tool would create better results than all thread? Dont get me wrong I have seen some great results actually in person with the small home units cupcake, makerbot, etc. (Houston Hackerspace) but it just seems it would be a better platform. Also my mill just sits so reallocating it for a while would be fine.
    Jul 2010
    Fastest,
    I don't think rigidity has anything to do with it, since there are no external forces that need to be braced against in a 3d printer. All the machine is working against is air loads as it moves about.
    I can see one of those machines working much faster, since there's less mass to move around, but rigidity wise I doubt there's a difference.
    Feb 2004
    I can't yet speak to the rigidity issue since I am still building my machine! Hoss has been making parts though with his. I can say that once all that all thread is tightened up, the machine isq pretty rigid. And, as stated above, there are no forces to speak of likes there are on a mill or router.
    All this said, I am building this machine to get my feet wet. I think a really simple machine could be built in aluminum like a CNC router that would be much simpler to construct and quite rigid too.
    Cheers,
    Michael
    Oct 2008
    Yes, I thought about it as well. I also thought about the wear and tear on my mill, having it tied up, and my mill doesn't do 400 ipm like most of these small printers.
    Richard
    Rev
    SX-3 Mill, 10x22 Lathe, RF-45 Mill, GH-1340 Enco Lathe
    Tinkerer
    Nov 2009
    Richard, really 400 ipm? Maybe not use my mill. I knew rigidity was not necessary for the actual extruding however the more rigid the machine, the faster you could push it, or so it would seem. Thanks for the reply. Eventually I will try it just for the challenge. That Sherline/A2ZCNC Monster mill isn't going to get used anymore unless I do make it into a printer.
    1. CNC mill & 3D printer Developer Kit - RepRap
      By CNCadmin in forum EBAY ADS
      Last Post: 12-19-2011, 10:40 AM
    2. CNC mill & 3D printer Developer Kit - RepRap
      Last Post: 12-12-2011, 08:20 PM
    3. CNC mill & 3D printer Developer Kit - RepRap
      Last Post: 12-06-2011, 12:10 AM
    4. Would anyone else want a 3D printer head for their mill?
      By Fastest1 in forum Benchtop Machines
      Last Post: 09-16-2011, 04:46 PM
    5. CNC Mill + Printer?
      By scruffyjones48 in forum DIY CNC Router Table Machines
      Last Post: 01-13-2009, 02:21 AM
