Results 1 to 2 of 2
Thread: Indicate holes for nordic track motor mount?
    Registered slatronic's Avatar
    Sep 2008
    I'm currently working on converting my KX3 clone to use Hoss's nordic track motor conversion. The sangmutan motor and control have no torque what so ever as others have commented on.
    My problem is how do I best indicate the holes around the outside circumference of the tube to hold motor? I dont have a rotary table but I do have a bridgeport mill to use. I'm guessing there has to be some trick to locate holes at 90* from each other. There is another option to use use epoxy but I would rather use four set screws at 90s around the motor. If its better to epoxy the motor let me know and I'll forget about indicating the holes.
    thanks
    jeff
    I'll include some pics of conversion after I get a little farther along.
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    You could mount the tube end down on the mill's table. Locate the center, and then it's a simple matter of using X and Y motion to move to each position.
    You will then need an L shaped scribe mounted in the spindle to make the marks on the outside wall of the tube.
    Alternately, lay the tube on its side. Find center, and drill all the way through. That gives you two of the four holes.
    Run a piece of drill rod through those holes, and put a level on the drill rod. Adjust until the rod is perfectly horizontal, and now you can drill your second two holes.
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
  1. motor mount for NM-145
    By tjd10684 in forum RFQ (Request for Quote)
    Last Post: 08-10-2011, 09:11 PM
  2. X2 Z-Axis Motor Mount
    By SSfab in forum Benchtop Machines
    Last Post: 01-13-2009, 04:28 PM
  3. Need Help!- How to mount a PCB board into a casing box that has no mounting holes?
    By selrahc in forum General Electronics Discussion
    Last Post: 01-04-2009, 07:00 AM
  4. Taig Motor Mount
    By sprinter in forum Taig Mills & Lathes
    Last Post: 12-24-2008, 04:06 AM
  5. Need help to create a motor mount
    By veegaa in forum Parts for Radio Control Models
    Last Post: 12-10-2007, 04:27 AM
