Results 1 to 3 of 3
Thread: Dynamyte dm 2100
    Jan 2008
    U.S.A.
    Dynamyte dm 2100
    I posted this in the dynamechtronics section and I figured I would try here also. I don't have any problems downloading programs or using the drip feed. But I do have a problem with the renumber program. I generally use sheetcam for making programs and I have held back on buying it, I just use the trial version which outputs about 400 lines. I would like to buy it, but I am having trouble with the renumber program from dyna. What happens is when I tell it to renumber somewhere around line 1000 or 1100, which is block 2 line 100 or 200, it starts loosing a few letters at the beginning of lines. ZERO AT becomes ERO AT and <REF COODS becomes REF COODS. Which basically makes the line blank at the machine. Has anyone else run into this, or might you have a different renumber program I can get? Any help would be great.Thanks for your time.
    Tinkerer
    Nov 2009
    Though you might get an answer here, look up a member named "Caprirs" (sp?) and pm him. He is very knowledgable in regards to Dyna and was a tech for them years ago IIRC. Good luck, I have a DM2400 and tried for a year or so to understand how to drip feed that machine (I dont know how to drip feed any machine so it wasnt that it might not be possible). Turned out easier to convert as I had some experience with Mach. Nice machine.
    Tinkerer
    Nov 2009
    Btw, I did send Bud the Dynacom.exe file and he was able to get it to do what he needed. Glad to know it finally went to good use. It had been on my computer for years but I didnt know how to use it and quickly converted my machine so it wasn't necessary.
  1. Dynamyte 2800 Manuals
    By bender88 in forum Benchtop Machines
    Last Post: 02-28-2012, 08:29 AM
  2. Need Help!- DynaMyte 2400 Manuals
    By VrSixed in forum Benchtop Machines
    Last Post: 12-09-2009, 09:30 PM
  3. Need Help!- DynaMyte 4400
    By echostar in forum DynaCNC
    Last Post: 05-12-2009, 09:45 AM
  4. Dynamyte 4400
    By olhippiebiker in forum General Metal Working Machines
    Last Post: 06-22-2007, 01:08 AM
